メインコンテンツまでスキップ
NetApp adopts Microsoft’s Business-to-Customer (B2C) Identity Management
Effective December 3 - NetApp adopts Microsoft’s Business-to-Customer (B2C) identity management to simplify and provide secure access to NetApp resources. For accounts that did not pre-register (prior to Dec 3) access to your NetApp data may take up to 1 hour as your legacy NSS ID is synchronized to the new B2C identity. To learn more, Read the FAQ and Watch the video. Need assistance? Complete this form and select “Registration Issue” as the Feedback Category.
Transient AutoSupport ( BATTERY ( BATTERY LOW )通知メッセージ
3
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
環境
  • AFF A250
  • BMC ファームウェア15.2
問題
  • EMSメッセージ
HA Group Notification from node_name (BATTERY(capacity low)) NOTICE
  • 一方または両方のノードで同じ問題が報告され、数秒後にクリアされました。
Fri Aug 06 10:15:39 +0200 [node_name_1: env_mgr: nvmem.battery.capLowWarn:error]: The NVMEM battery capacity is below normal (5 cycles).
Fri Aug 06 10:16:39 +0200 [node_name_1: env_mgr: callhome.battery.notice:notice]: Call home for BATTERY (capacity low) NOTICE.
Fri Aug 06 10:32:49 +0200 [node_name_1: env_mgr: nvmem.battery.capNormal:notice]: The NVMEM battery capacity is normal.
Thu Aug 05 00:02:49 +0200 [node_name_2: env_mgr: nvmem.battery.capLowWarn:error]: The NVMEM battery capacity is below normal (5 cycles).
Thu Aug 05 00:03:49 +0200 [node_name_2: env_mgr: callhome.battery.notice:notice]: Call home for BATTERY (capacity low) NOTICE.
Thu Aug 05 00:32:09 +0200 [node_name_2: env_mgr: nvmem.battery.capNormal:notice]: The NVMEM battery capacity is normal.
  • その他の関連エラーは報告されていません。
  • BMC / e0M ポートでは大量のトラフィックが検出されます。例:
eth0    Link encap:Ethernet  HWaddr D0:39:EA:47:11:31
      inet addr:192.168.0.1  Bcast:192.168.0.255  Mask:255.255.255.0
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
      RX packets:539889 errors:0 dropped:277459 overruns:0 frame:0
      TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:54208615 (51.6 MiB)  TX bytes:624 (624.0 B)
      Interrupt:32
-- interface  e0M  (34 days, 11 hours, 25 minutes, 25 seconds) --
RECEIVE
 Total frames:    110m| Frames/second:    37  | Total bytes:    20986m
 Bytes/second:    7045  | Total errors:     0  | Errors/minute:     0
 Total discards:    0  | Discards/minute:    0  | Multi/broadcast:   569k
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
