ワークロードセキュリティデータコレクターは、ネットワーク障害発生後に自動的に復旧しません
環境
- Data Infrastructure Insights(DII、旧Cloud Insights)
- Storage Workload Security
- 以前に発生したネットワークの問題
問題
- Data Collectorは
ErrorステータスでWorkload Security > Collectors > Data Collectorsに表示され、一時的なネットワーク障害の後に次のメッセージが表示されます:
Connector is in error state. Service name: audit. Reason for failure: External fpolicy server terminated.
- Data Infrastructure Insightsはアラートを送信します:
Description: SVM Data Collector '<DATA_COLLECTOR_NAME>' is disconnected. The SVM is not monitored and protected.
Error: Connector is in error state. Service name: audit. Reason for failure: External fpolicy server terminated.
Data Collector name: <DATA_COLLECTOR_NAME>
dsc.logエラーを報告します:
2023-06-29T02:32:14,874 [ERROR] [prod] [<ID>] [<DATA_COLLECTOR_ID>] [3733] [datasource-AppManager] - Service audit failed with reason: External fpolicy server terminated.
2023-06-29T02:32:14,890 [INFO] [prod] [<ID>] [<DATA_COLLECTOR_ID>] [3733] [datasource-AuditManager] - Starting a singleTimer for audit service after 15 minutes
2023-06-29T02:47:18,009 [ERROR] [prod] [<ID>] [<DATA_COLLECTOR_ID>] [3733] [datasource-AuditManager] - Exception occurred while starting : Connection error to Storage System <STORAGE_IP>: No route to host (Host unreachable)
