メインコンテンツまでスキップ
複数のファンに障害が発生すると、システムがシャットダウンし
100
Visibility:
Votes:
0
Category:
fas-systems<a>2008848178</a>
Specialty:
hw
Last Updated:
環境
  • AFFとFAS
  • ONTAP 9
  • Data ONTAP 8
問題
ファン障害メッセージが表示され、システムがシャットダウンします。
  • EMS ログ
Jul 16 23:22:58 [node-1:callhome.shlf.fan:EMERGENCY]: Call home for SHELF COOLING UNIT FAILED
Jul 16 23:23:07 [node-1:monitor.fan.critical:EMERGENCY]: 2 fans have failed. Replace them to avoid overheating. If not corrected, system will shutdown in 2 minutes.
Jul 16 23:23:37 [node-1:callhome.fans.failed:EMERGENCY]: Call home for MULTIPLE FAN FAILURE
Jul 16 23:25:27 [node-1:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Multiple fans failed)
  • AC_Power_Fail Asserted Deasserted Service Processor ( SP ;サービスプロセッサ)events all ログで、エラーが繰り返し報告されます。
Record 2043: Sat Jul 17 08:03:44 2021 [IPMI Event.critical]: IPMI SEL log limit exceeded
Record 2044: Sat Jul 17 08:03:44 2021 [IPMI.notice]: fc07 | 02 | EVT: 0300ffff | AC_Power_Fail | Assertion Event, "State Deasserted"
Record 2045: Sat Jul 17 08:03:48 2021 [SP.warning]: Agent IIRQ false alarm
Record 2046: Sat Jul 17 08:04:06 2021 [IPMI Event.critical]: IPMI SEL log limit exceeded
Record 2047: Sat Jul 17 08:04:06 2021 [IPMI.notice]: fd07 | 02 | EVT: 0301ffff | AC_Power_Fail | Assertion Event, "State Asserted"
Record 2048: Sat Jul 17 08:04:08 2021 [IPMI Event.critical]: IPMI SEL log limit exceeded
Record 2049: Sat Jul 17 08:04:08 2021 [IPMI.notice]: fe07 | 02 | EVT: 0300ffff | AC_Power_Fail | Assertion Event, "State Deasserted"
Record 2050: Sat Jul 17 08:04:09 2021 [IPMI Event.critical]: IPMI SEL log limit exceeded
Record 2051: Sat Jul 17 08:04:09 2021 [IPMI.notice]: ff07 | 02 | EVT: 0301ffff | AC_Power_Fail | Assertion Event, "State Asserted"
  • CPU 関連の情報を SPsystem sensors 出力から読み取ることはできません。
Sensor Name    | Current   | Unit     | Status    | LCR     | LNC     | UNC     | UCR
CPU0_Temp_Margin | na     | degrees C  | na     | na     | na     | -5.000   | 0.000
In_Flow_Temp    | 24.000    | degrees C  | ok      | 0.000    | 10.000   | 70.000   | 75.000
Out_Flow_Temp   | 23.000    | degrees C  | ok      | 0.000    | 10.000   | 82.000   | 87.000
Memory_Hot     | 0x0     | discrete   | Deasserted | na     | na     | na     | na
CPU_Hot      | 0x0     | discrete   | Deasserted | na     | na     | na     | na
CPU_Cat_Error   | 0x0     | discrete   | Deasserted | na     | na     | na     | na
CPU_Therm_Trip   | 0x0     | discrete   | Deasserted | na     | na     | na     | na
CPU_VCC      | na     | Volts    | na     | 0.708    | 0.747    | 1.348    | 1.426
CPU_1.05V     | na     | Volts    | na     | 0.892    | 0.941    | 1.154    | 1.203
CPU_VTT      | na     | Volts    | na     | 0.931    | 0.989    | 1.213    | 1.261
LM56_Temp     | na     | degrees C  | na     | 0.000    | 10.000   | 79.000   | 84.000
CPU_1.5V      | na     | Volts    | na     | 1.271    | 1.348    | 1.649    | 1.727
1G_1.0V      | na     | Volts    | na     | 0.854    | 0.902    | 1.096    | 1.154
FC_0.9V      | na     | Volts    | na     | 0.776    | 0.815    | 0.989    | 1.038
FC_1.0V      | na     | Volts    | na     | 0.854    | 0.902    | 1.096    | 1.154
USB_5.0V      | na     | Volts    | na     | 4.253    | 4.495    | 5.492    | 5.759
PCH_3.3V      | na     | Volts    | na     | 2.798    | 2.973    | 3.625    | 3.800
SASS_1.0V     | na     | Volts    | na     | 0.854    | 0.902    | 1.096    | 1.145
SASS_1.2V     | na     | Volts    | na     | 1.018    | 1.077    | 1.319    | 1.377
IB_1.2V      | na     | Volts    | na     | 1.018    | 1.077    | 1.319    | 1.37
New to NetApp?
