メインコンテンツまでスキップ
AFF8080ルートポート0、2、0でPCIエラーNMIが一時停止しています
11
Visibility:
Votes:
0
Category:
aff-series<a>2009534805.</a>
Specialty:
hw
Last Updated:
環境
  • AFF8080
  • ONTAP 9
問題
ルートポート0、2、0でPCIエラーNMIが発生してノードがパニック状態になります。
  • SPシステムログ:
::> 0x0051de0b00847be4: Add bad root port 0/2/0 (1)
0x0051de0b00cddda8: 0/2/0 ucerr_status 0x4000
0x0051de0b00cded10: Recovery process terminated
PANIC  : PCI Error NMI from device(s):ErrSrcID(CorrSrc(0x810),UCorrSrc(0x10)), RPT(0,2,0):
version: 9.5P19: Sat Nov 27 01:46:06 EST 2021
conf   : x86_64.optimize
cpuid = 18
Uptime: 95d11h22m33s
PANIC: PCI Error NMI from device(s):ErrSrcID(CorrSrc(0x810),UCorrSrc(0x10)), RPT(0,2,0): in SK process nblade1 on release 9.5P19 (C)
  • ASUPのSSRAM-LOG(スロット4のデバイス8、2、0)で修正不能なエラーを確認します。
Fri Apr 7 03:53:43 2023 SRAM record type(LOG) from Data ONTAP: NMIsource(PCIErr).
Fri Apr 7 03:53:43 2023 SRAM record type(LOG) from Data ONTAP: IIO0gblfe(0x0), gblne(0x100)
Fri Apr 7 03:53:43 2023 SRAM record type(LOG) from Data ONTAP: IIO1gblfe(0x0), gblne(0x0)
Fri Apr 7 03:53:43 2023 SRAM record type(LOG) from Data ONTAP: RPT(0,2,0):
Fri Apr 7 03:53:43 2023 SRAM record type(LOG) from Data ONTAP: BSF(0:2:0) status = 0x4010
Fri Apr 7 03:53:43 2023 SRAM record type(LOG) from Data ONTAP: BSF(0:2:0) dev_status = 0x3
Fri Apr 7 03:53:43 2023 SRAM record type(LOG) from Data ONTAP: BSF(0:2:0) root_sts = 0x27
Fri Apr 7 03:53:43 2023 SRAM record type(LOG) from Data ONTAP: BSF(0:2:0) corr_sts = 0x2000
Fri Apr 7 03:53:43 2023 SRAM record type(LOG) from Data ONTAP: BSF(0:2:0) ucorr_sts = 0x4000
Fri Apr 7 03:53:43 2023 SRAM record type(LOG) from Data ONTAP: Br[806c](8,2,0) in slot 4:
Fri Apr 7 03:53:43 2023 SRAM record type(LOG) from Data ONTAP: BSF(8:2:0) dev_status = 0x1
Fri Apr 7 03:53:43 2023 SRAM record type(LOG) from Data ONTAP: BSF(8:2:0) corr_sts = 0x10c1
Fri Apr 7 03:53:43 2023 SRAM record type(PCI) from Data ONTAP: device(8, 2, 0) in slot(4)
Fri Apr 7 03:53:43 2023 SRAM record type(LOG) from Data ONTAP: AGUS,1_0.IIO0: GNERR<0x00000100>(P2A), GNFERR<0x00000100>(P2A); RPT(0,2,0): GLB<0x00000002>(NFERR), PTR<0x1>, Status(SigSysErr), DevStatus(Corr,NFatal), RootErr(Corr,MCorr,UCor,NFatal), ErrSrcID(CorrSrc(0x810),UCorrSrc(0x10)), CorrErr(AdvsNF), UCorrErr(CpTim), FirstUCorrErr(CpTim); Br[806c](8,2,0) in slot 4: DevStatus(Corr), CorrErr(Rcvr,BTLP,BDLLP,RpTim).
  • sysconfig -ac スロット4のカードの詳細を表示します。
sysconfig: slot 1 OK: X1132A: QLogic ISP 2532; Quad Ported 2532 FCP Adapter (PCIe)
sysconfig: slot 3 OK: X1132A: QLogic ISP 2532; Quad Ported 2532 FCP Adapter (PCIe)
sysconfig: slot 4 OK: X1132A: QLogic ISP 2532; Quad Ported 2532 FCP Adapter (PCIe)
New to NetApp?
