AIQUM 9.14以降でクラスタの取得が停止する
環境
- Active IQ Unified Manager(AIQUM)9.14以降
- ONTAP 9.14以降
問題
- クラスタの取得を実行中に何時間も停止する
Cluster discovery failed. Rediscover the cluster after resolving the issue
Unable to add cluster datasource. This can occur if the clocks on the systems are not synchronized and the Active IQ Unified Manager HTTPS certificate start date is later than the date on the cluster, or if the cluster has reached the maximum number of EMS notification destinations.
- クラスタの取得に失敗します。
au.log
ERROR [Thread-4] o.a.q.j.JmsConnection (JmsConnection.java:165) - Failed to connect to remote at: amqp://localhost:56072
WARN [Thread-4] c.n.a.d.a.DataCollectorTrigger (DataCollectorTrigger.java:210) - Failed to connect to Broker, will retry shortly
- 1日の特定の時間に取得が失敗するが、サーバのリブート/再起動後に一時的に修正される
- レポート
server_acq.log
2024-05-21 10:55:23,416 ERROR [QpidJMS Connection Executor: ID:d5f45294-5f41-4e89-8a0c-45a91bcebd67:1] c.n.s.m.JmsBase (JmsBase.java:238) - Disconnected from Broker, retrying to connect
2024-05-21 10:55:23,406 ERROR [QpidJMS Connection Executor: ID:a3dc0377-2513-45f9-814a-9a0f9d239ac5:1] c.n.s.m.JmsBase (JmsBase.java:236) - Linked Exception: org.apache.qpid.jms.provider.exceptions.ProviderConnectionRemotelyClosedException: Connection closed by external action [condition = amqp:connection:forced]
2024-05-21 10:55:23,416 ERROR [QpidJMS Connection Executor: ID:a3dc0377-2513-45f9-814a-9a0f9d239ac5:1] c.n.s.m.JmsBase (JmsBase.java:238) - Disconnected from Broker, retrying to connect
2024-05-21 10:55:23,421 INFO [Thread-184] c.n.s.m.JmsBase (JmsBase.java:103) - Trying to connect to Broker
