メインコンテンツへスキップ
DIIおよびOCIのONTAPデータコレクタがfcp-interface-get-iter ZAPIで失敗し、fcp_portのnext()でループが検出されました
69
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
環境
  • Data Infrastructure Insight(DII)
  • OnCommand Insight (OCI)
  • ONTAP 9.15.1以降
問題
  • アップグレード後にDII/OCIのONTAPデータコレクタが失敗する
  • エラー:
ERROR [com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource] <ONTAP_Cluster> [Error retrieving data] - fcp-interface-get-iter failed: Loop detected in next() for table fcp_port. Next on "<port 1>" returned "<port 1>".
([Device name fcp-interface-get-iter]: fcp-interface-get-iter failed: Loop detected in next() for table fcp_port. Next on "<port 1>" returned "<port 1>".)
com.onaro.sanscreen.acquisition.framework.datasource.DataSourceErrorException: fcp-interface-get-iter failed: Loop detected in next() for table fcp_port. Next on "<port 1>" returned "<port 1>".
at com.onaro.sanscreen.acquisition.datasource.netapp_ontap.builder.ZapiIterBase.build(ZapiIterBase.java:240) ~[netapp_ontap.jar:?]
at com.onaro.sanscreen.acquisition.datasource.netapp_ontap.builder.ZapiIterBase.build(ZapiIterBase.java:122) ~[netapp_ontap.jar:?]
at com.onaro.sanscreen.acquisition.datasource.netapp_ontap.builder.ClusterBuilder$FoundationQueryFunction.queryData(ClusterBuilder.java:959) ~[netapp_ontap.jar:?]
at com.onaro.sanscreen.acquisition.datasource.netapp_ontap.builder.ClusterBuilder$FoundationQueryFunction.queryData(ClusterBuilder.java:852) ~[netapp_ontap.jar:?]
at com.onaro.sanscreen.acquisition.util.parallel.ParallelExecution$QueryTask.call(ParallelExecution.java:259) ~[netapp_ontap.jar:?]
at com.onaro.sanscreen.acquisition.util.parallel.CallableWrapper.call(CallableWrapper.java:41) ~[netapp_ontap.jar:?]
  • fcp-interface-get-iterの手動トリガー:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<netapp xmlns="http://www.netapp.com/filer/admin" version="1.0">
 <fcp-interface-get-iter>
  <max-records>200</max-records>
  <desired-attributes>
   <fcp-interface-info>
    <interface-name/>
    <node-name/>
    <port-name/>
    <vserver/>
   </fcp-interface-info>
  </desired-attributes>
  <tag><fcp-interface-get-iter-key-td><key-0><Port 0></key-0><key-1><Port 1></key-1></fcp-interface-get-iter-key-td></tag>
 </fcp-interface-get-iter>
</netapp>
<<< REQUESTEND >>>
<<< RESPONSE >>>
HTTP/1.1 200 OK
Date: Mon, 13 Jan 2025 17:03:53 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache, no-store, must-revalidate
Deprecation: true
Content-Length: 364
Content-Type: text/xml
Keep-Alive: timeout=5, max=41
Connection: Keep-Alive
<?xml version='1.0' encoding='UTF-8' ?>
<!DOCTYPE netapp SYSTEM 'file:/etc/netapp_gx.dtd'>
<netapp version='1.251' xmlns='http://www.netapp.com/filer/admin'>
<results reason="Loop detected in next() for table fcp_port. Next on "<Port 1>" returned "<Port 1>"." status="failed"errno="13001"/></netapp>
New to NetApp?
