SG57xx NVRAM および SFP の StorageGRID Webscale アプライアンスインストーラファームウェアバージョン 2.0.0 を 2.0.1 にアップグレードする方法が正しくありません
環境
- StorageGRIDアプライアンス
- StorageGRID Webscale
概要
この記事では、 SG5712 および SG5760 ( E5700SG とも呼ばれます)を StorageGRID Webscale アプライアンスインストーラ 2.0.1 にアップグレードする手順について説明しています。このアップグレードでは、 Support_Bulletins に記載されている問題を解決します。
SU298 : StorageGRID Webscale SG57XX ソフトウェアインストーラ 2.0.0 の導入設定が正しくありません
README.txt
Important: Please Read
NOTE: StorageGRID Webscale Appliances come from the factory preinstalled with all necessary firmware. You do not need to, and should not, manually apply a StorageGRID Webscale Appliance firmware upgrade or downgrade, unless you are instructed to do so by NetApp support. In that event, you can find all current versions of the StorageGRID Appliance firmware in this zip archive.
NOTE: This archive contains firmware for the E5600SG controller in a StorageGRID Webscale Appliance (SG56xx). If you need to upgrade the firmware in the E2700 controller, you must contact NetApp Technical Support to obtain the correct firmware download files, including the StorageGRID Webscale Appliance version of the E2700 NVSRAM download, which has a -SG1.dlp suffix. DO NOT apply any other E2700 NVSRAM loads to the E2700 controller in a StorageGRID Webscale Appliance.
NOTE: This archive contains firmware for the E5700SG controller in a StorageGRID Webscale Appliance (SG57xx). If you need to upgrade the firmware in the E2800 controller, you must contact NetApp Technical Support to obtain the correct firmware download files, including the StorageGRID Webscale Appliance version of the E2800 NVSRAM download, which has a -SG2.dlp suffix. DO NOT apply any other E2800 NVSRAM loads to the E2800 controller in a StorageGRID Webscale Appliance (SG57xx).
NOTE: This firmware can only be applied to StorageGRID Webscale Appliances that are in a preinstalled state. If you have already installed StorageGRID Webscale software on your StorageGRID Webscale Appliances, firmware upgrades or downgrades to the version used by your StorageGRID Webscale software release will be applied automatically by the system. No further action is required.
Contents of this Archive
1. StorageGRID-Webscale-Appliance-Firmware/README.txt
This file.
2. StorageGRID-Webscale-Appliance-Firmware/E5600SG
Subdirectories containing StorageGRID Webscale Appliance firmware versions for the E5600SG controller in a StorageGRID Webscale Appliance (SG56xx).
3. StorageGRID-Webscale-Appliance-Firmware/E5600SG/Version-1.3-for-SGWS-10.2
File Size File Name
85 NetApp-PGE_1.3.0-20150422.1458.a2bf977.bin.sha1
336422351 NetApp-PGE_1.3.0-20150422.1458.a2bf977.bin.tar.bz2
Installer firmware image (.tar.bz2) and firmware image SHA1 signature (.bin.sha1) for StorageGRID Webscale Appliance Installer firmware version 1.3.0.
Use this firmware with systems running StorageGRID Webscale version 10.2.
4. StorageGRID-Webscale-Appliance-Firmware/E5600SG/Version-1.6-for-SGWS-10.3
File Size File Name
85 NetApp-PGE_1.6.0-20160413.1739.3810b38.bin.sha1
306800581 NetApp-PGE_1.6.0-20160413.1739.3810b38.bin.tar.bz2
Installer firmware image (.tar.bz2) and firmware image SHA1 signature (.bin.sha1) for StorageGRID Webscale Appliance Installer firmware version 1.6.0.
Use this firmware with systems running StorageGRID Webscale version 10.3.
5. StorageGRID-Webscale-Appliance-Firmware/E5600SG/Version-1.7-for-SGWS-10.4
File Size File Name
85 NetApp-PGE_1.7.0-20170209.2006.782b44c.bin.sha1
425080246 NetApp-PGE_1.7.0-20170209.2006.782b44c.bin.tar.bz2
Installer firmware image (.tar.bz2) and firmware image SHA1 signature (.bin.sha1) for StorageGRID Webscale Appliance Installer firmware version 1.7.0.
Use this firmware with systems running StorageGRID Webscale version 10.4.
6. StorageGRID-Webscale-Appliance-Firmware/E5600SG/Version-2.0-for-SGWS-11.0
File Size File Name
85 NetApp-PGE_2.0.1-20180103.2049.e7f61c1.bin.sha1
447921955 NetApp-PGE_2.0.1-20180103.2049.e7f61c1.bin.tar.bz2
Installer firmware image (.tar.bz2) and firmware image SHA1 signature (.bin.sha1) for StorageGRID Webscale Appliance Installer firmware version 2.0.1.
Use this firmware with systems running StorageGRID Webscale version 11.0.
7. StorageGRID-Webscale-Appliance-Firmware/E5700SG
Subdirectories containing StorageGRID Webscale Appliance firmware versions for the E5700SG controller in a StorageGRID Webscale Appliance (SG57xx).
8. StorageGRID-Webscale-Appliance-Firmware/E5700SG/Version-2.0-for-SGWS-10.3-through-11.0
File Size File Name
Installer firmware image (.tar.bz2) and firmware image SHA1 signature (.bin.sha1) for StorageGRIDWebscale Appliance Installer firmware version 2.0.1.
Use this firmware with systems running StorageGRIDWebscale version 10.3, 10.4, and 11.0.
