FAS8200システムでは、「A power sensor P12V STBY in the controller module is not readable」というエラーが頻繁に発生します。
環境
FAS8200
問題
EMSログにセンサーP12V STBY記録されている場合、エラーmonitor.power.unreadable複数回発生します。
[?] Tue Jul 16 00:21:11 +0900 [node-1: env_mgr: monitor.power.unreadable:error]: A power sensor P12V STBY in the controller module is not readable.
[?] Tue Jul 16 00:23:01 +0900 [node-1: env_mgr: monitor.chassisPower.ok:notice]: Chassis power is OK.
[?] Tue Jul 16 00:24:24 +0900 [node-1: env_mgr: monitor.power.unreadable:error]: A power sensor P12V STBY Curr in the controller module is not readable.
[?] Tue Jul 16 00:37:59 +0900 [node-1: env_mgr: monitor.chassisPower.ok:notice]: Chassis power is OK.
[?] Tue Jul 16 00:39:26 +0900 [node-1: env_mgr: monitor.power.unreadable:error]: A power sensor P12V STBY Curr in the controller module is not readable.
[?] Tue Jul 16 00:51:14 +0900 [node-1: env_mgr: monitor.power.unreadable:error]: A power sensor P12V Curr in the controller module is not readable.
[?] Tue Jul 16 00:51:32 +0900 [node-1: env_mgr: monitor.power.unreadable:error]: A power sensor P12V STBY in the controller module is not readable.
[?] Tue Jul 16 00:59:52 +0900 [node-1: env_mgr: monitor.power.unreadable:error]: A power sensor P12V Curr in the controller module is not readable.
[?] Tue Jul 16 04:39:23 +0900 [node-1: env_mgr: monitor.power.unreadable:error]: A power sensor P12V STBY in the controller module is not readable.
[?] Tue Jul 16 04:39:44 +0900 [node-1: env_mgr: monitor.power.unreadable:error]: A power sensor P12V STBY Curr in the controller module is not readable.
[?] Tue Jul 16 04:55:59 +0900 [node-1: env_mgr: monitor.chassisPower.ok:notice]: Chassis power is OK.
[?] Tue Jul 16 04:57:26 +0900 [node-1: env_mgr: monitor.power.unreadable:error]: A power sensor P12V STBY Curr in the controller module is not readable.
SP-LATEST-SYSLOGにSensor 212とSensor 213読み取りエラーが表示されます。
Jul 15 19:39:04 (none) : [392 WARNING][hal_api.c:356]Sensor 212 reading error
Jul 15 19:39:04 (none) : [392 WARNING][hal_api.c:356]Sensor 213 reading error
Jul 15 19:39:11 (none) hsam[357]: HSAM OS(0x5):cmd(2) FLD(controller):fault(Failed reading sensor: 212)
Jul 15 19:39:11 (none) : [392 WARNING][hal_api.c:356]Sensor 213 reading error
Jul 15 19:39:17 (none) : [392 WARNING][hal_api.c:356]Sensor 212 reading error
Jul 15 19:39:17 (none) : [392 CRITICAL][Porting/platform/PDKHooks.c:647]Error while reading sensor number : 212
Jul 15 19:39:17 (none) : [392 WARNING][hal_api.c:356]Sensor 213 reading error
Jul 15 19:39:24 (none) env_mgr[1109]: Payload EMS: EMS_monitor_power_unreadable(P12V STBY)
PLATFORM-SENSORSのP12V関連センサーに問題はありません。
P12V voltage normal 11904 mV 0 15810
P12V Curr current normal 7896 mA 0 21420
P12V STBY voltage normal 11904 mV 0 15810
P12V STBY Curr current normal 811 mA 0 3182
SP-LATEST-IPMI,ではP12V_STBYとP12V_STBY_Curr両方にnaステータスがあり、Failed reading sensor: 213と表示されます。
hsamcmd --fault-show-all
tag origin fld fault reason count time
1 0x5 /chassis-1/controller-b Failed reading sensor: 213 1 Mon Jul 15 20:04:51 2024
P12V | 11.904 | Volts | ok | 0.000 | 0.000 | 15.810 | 15.810
P12V_Curr | 7.728 | Amps | ok | 0.000 | 0.000 | 21.420 | 21.420
P12V_STBY | na | Volts | na | 0.000 | 0.000 | 15.810 | 15.810
P12V_STBY_Curr | na | Amps | na | 0.000 | 0.000 | 3.182 | 3.182
