メインコンテンツまでスキップ
バッテリ(存在しない)クリティカル FAS27xx と AFF A220 については、ご自宅にお問い合わせください
42
Visibility:
Votes:
0
Category:
aff-series<a>2008704035</a>
Specialty:
hw
Last Updated:
環境
  • AFF A220
  • AFF C190用
  • FAS2750
  • FAS2720
問題
  • 起動時のエラーレポート:
WARNING: The battery is unfit to retain data during a power outage. This is likely because the battery is discharged but could be due to other temporary conditions. When the battery is ready, the boot process will complete and services will be engaged. To override this delay, press 'c' followed by 'Enter
Mar 24 06:49:59 [node:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (not present) CRITICAL.
Mar 24 06:51:00 [node:nvmem.battery.notPresent:ALERT]: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.
  • システムがバッテリパックを認識できません:
::> system node environment sensors show
Bat_Temp      | na     | degrees C  | na      | 0.000    | 5.000    | 56.000   | 60.000
Bat_Volt      | na     | Volts    | na      | 5.500    | 5.600    | 8.500    | 8.600
Bat_Curr      | na     | Amps     | na      | na     | na     | 1.520    | 1.800
Bat_Rem_Cap    | na     | Amps * hour | na      | na     | na     | na     | na
Bat_Full_Cap    | na     | Amps * hour | na      | na     | na     | na     | na
Bat_Charge_Curr  | na     | Amps     | na      | na     | na     | 2.400    | 2.900
Bat_Charge_Volt  | na     | Volts    | na      | na     | na     | 8.900    | 9.000
Bat_Design_Cap   | na     | Amps * hour | na      | na     | na     | na     | na
Bat_Initial_Fcc  | na     | Amps * hour | na      | na     | na     | na     | na
Bat_Average_Temp | na     | degrees C  | na      | na     | na     | na     | na
Bat_Rem_Cap_off  | na     | Amps * hour | na      | na     | na     | na     | na
Bat_Dstg_Cycles  | na     | cycles    | na      | 2.000    | 5.000    | na     | na
Bat_Power_Fault  | 0x0     | discrete   | Asserted   | na     | na     | na     | na
Bat_Dsg_FET_Flt  | na     | discrete   | na      | na     | na     | na     | na
Bat_Chg_FET_Flt  | na     | discrete   | na      | na     | na     | na     | na
Bat_Pack_Invalid | na     | discrete   | na      | na     | na     | na     | na
Bat_Cycle_Cnt   | na     | cycles    | na      | na     | na     | na     | na
Bat_Lrn_Active   | na     | discrete   | na      | na     | na     | na     | na
New to NetApp?
