メインコンテンツまでスキップ
EMS レポート「 Chassis power supply is degraded 」に続いてサービスが停止しています プロセッサが DHCP を使用してネットワーク設定を取得できない
39
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
に適用されます
  • サービス プロセッサ(SP)
  • Baseboard Management Controller(BMC)
  • 電源装置( PSU )
問題
  • EMS で、 PSU エラーの前に SP エラーが報告される。
例:
Mon Oct 19 00:35:39 +0800 [node-01: servprocd: sp.dhcp.failure:error]: Service Processor cannot obtain network configuration using DHCP.
  • EMS がシャーシの電源装置が劣化していると報告します。
例:
[?] Mon Oct 19 00:38:10 +0800 [node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Power Out is Unreadable
[?] Mon Oct 19 00:38:10 +0800 [node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Curr Out is Unreadable
[?] Mon Oct 19 00:38:10 +0800 [node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Volt Out is Unreadable
[?] Mon Oct 19 00:38:10 +0800 [node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Power In is Unreadable
[?] Mon Oct 19 00:38:11 +0800 [node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 FAN is Unreadable
[?] Mon Oct 19 00:38:11 +0800 [node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Curr In is Unreadable
[?] Mon Oct 19 00:38:11 +0800 [node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Volt In is Unreadable
  • シャーシ PSU は手動で確認することで良好です。
New to NetApp?
