メインコンテンツまでスキップ
故障LEDが点灯し、PCMステータスが「P SHELF FAULT RQSTD」と表示される
65
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
環境
  • FAS26X0
  • FAS2750
問題
  • コントローラの障害LEDが点灯している。
  • storage show fault -v 次の情報が表示されます。
Enclosure Status: critical
Channel: 0a
Shelf: 0
Shelf Type: DS212-12
Product Serial Number: SHJSG1751000163
Module Type: IOM12E
Disk Elements:
Element Status          Status Bytes  Status Descriptions
  0 [Bay  0]: OK         01,00,00,00
  1 [Bay  1]: OK         01,01,00,20   FAULT REQSTD
  2 [Bay  2]: OK         01,02,00,00
  3 [Bay  3]: OK         01,03,00,20   FAULT REQSTD
  4 [Bay  4]: OK         01,04,00,00
  5 [Bay  5]: OK         01,05,00,20   FAULT REQSTD
  6 [Bay  6]: OK         01,06,00,00
  7 [Bay  7]: OK         01,07,00,20   FAULT REQSTD
  8 [Bay  8]: OK         01,08,00,00
  9 [Bay  9]: OK         01,09,00,20   FAULT REQSTD
 10 [Bay 10]: OK         01,0A,00,00
 11 [Bay 11]: OK         01,0B,00,20   FAULT REQSTD
  0 [Bay  0]:           FF,00,00,00
Vendor Unique Element 85-IOM12E: (ACP)
 1 [IOM12E A]   : CRITICAL      02,18,00,00   NO ACPP, INBACP
  2 [IOM12E B]   : OK         01,18,00,00   NO ACPP, INBACP
Vendor Unique Element 88-IOM12E: (PCM)
  1: OK         01,01,80,00  SP SHELF FAULT RQSTD
  2: OK         01,01,80,00   SP SHELF FAULT RQSTD
  • EMSから 複数のセンサーエラーが報告される
3/17/2022 09:55:32  node01   ALERT      hm.alert.raised: Alert Id = SPNotConfiguredAlert , Alerting Resource = SP Config raised by monitor controller
3/17/2022 09:00:00  node01   ALERT      monitor.shelf.fault: Critical fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
3/17/2022 09:00:00  node02   ALERT      monitor.shelf.fault: Critical fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
3/17/2022 08:11:57  node02   ALERT      hm.alert.raised: Alert Id = SPNotConfiguredAlert , Alerting Resource = SP Config raised by monitor controller
3/17/2022 08:05:32  node01   ALERT      hm.alert.raised: Alert Id = SPNotConfiguredAlert , Alerting Resource = SP Config raised by monitor controller
3/17/2022 08:00:00  node01   ALERT      monitor.shelf.fault: Critical fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
3/17/2022 08:00:00  node02   ALERT      monitor.shelf.fault: Critical fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
3/17/2022 07:00:00  node01   ALERT      monitor.shelf.fault: Critical fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
3/17/2022 07:00:00  node02   ALERT      monitor.shelf.fault: Critical fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
New to NetApp?
  • この記事は役に立ちましたか?
