AFF A400のe0eポートに接続されたNexusスイッチで10を超える入力エラーが発生しています
環境
- AFF A400
- メザニンカード (X1161A) e0e、e0f、e0g、e0h ポート
- Nexus スイッチ
問題
- アン
Input Errors Over 10AFF A400メザニンカードのe0eポートのピアNexusスイッチでエラーが検出されました。
Input Errors Over 10 detection:<switch name> Ethernet5/3 is InErrors Over10
EMS logレポートvifmgr.cluscheck.hwerrorsアラート。
[?] Thu May 22 01:07:42 +0900 [node-01: vifmgr: vifmgr.cluscheck.hwerrors:alert]: Port e0f on node node-01 is reporting a high number (at least 1 per 1000 packets) of observed hardware errors (CRC, length, alignment, dropped).
[?] Thu May 22 03:17:42 +0900 [node-01: vifmgr: vifmgr.cluscheck.hwerrors:alert]: Port e0f on node node-01 is reporting a high number (at least 1 per 1000 packets) of observed hardware errors (CRC, length, alignment, dropped).
[?] Thu May 22 05:12:43 +0900 [node-01: vifmgr: vifmgr.cluscheck.hwerrors:alert]: Port e0e on node node-01 is reporting a high number (at least 1 per 1000 packets) of observed hardware errors (CRC, length, alignment, dropped).
- IFSTAT-A出力は
Total errorsそしてlong framesカウントは増えているが、CRC errors。
-- interface e0e (1 day, 22 hours, 36 minutes, 20 seconds) --
RECEIVE
Total frames: 1216m | Frames/second: 7250 | Total bytes: 1414g
Bytes/second: 8431k | Total errors: 343k | Errors/minute: 123
Total discards: 588 | Discards/minute: 0 | Multi/broadcast: 38102k
Non-primary u/c: 0 | Errored frames: 0 | Unsupported Op: 0
CRC errors: 0 | Runt frames: 0 | Fragment: 0
Long frames: 343k | Jabber: 0 | Length errors: 1
Alignment errors: 0 | No buffer: 588 | Pause: 0
Jumbo: 0 | Error symbol: 0 | Bus overruns: 0
Queue drops: 0 | LRO segments: 261m | LRO bytes: 1234g
LRO6 segments: 0 | LRO6 bytes: 0 | Bad UDP cksum: 0
Bad UDP6 cksum: 0 | Bad TCP cksum: 0 | Bad TCP6 cksum: 0
Mcast v6 solicit: 0 | Lagg errors: 0 | Lacp errors: 0
Lacp PDU errors: 0
TRANSMIT
Total frames: 1049m | Frames/second: 6256 | Total bytes: 953g
Bytes/second: 5680k | Total errors: 0 | Errors/minute: 0
Total discards: 0 | Queue overflow: 0 | Multi/broadcast: 74425
Collisions: 0 | Pause: 0 | Jumbo: 516m
Cfg Up to Downs: 0 | TSO segments: 40407k | TSO bytes: 779g
TSO6 segments: 0 | TSO6 bytes: 0 | HW UDP cksums: 0
HW UDP6 cksums: 0 | HW TCP cksums: 0 | HW TCP6 cksums: 0
Mcast v6 solicit: 0 | Lagg drops: 0 | Lagg no buffer: 0
Lagg no entries: 0
DEVICE
Mcast addresses: 3 | Rx MBuf Sz: 4096
LINK INFO
Speed: 10000M | Duplex: full | Flowcontrol: full
Media state: active | Up to downs:
-- interface e0f (1 day, 22 hours, 36 minutes, 20 seconds) --
RECEIVE
Total frames: 354m | Frames/second: 2112 | Total bytes: 150g
Bytes/second: 897k | Total errors: 343k | Errors/minute: 123
Total discards: 0 | Discards/minute: 0 | Multi/broadcast: 38102k
Alignment errors: 0 | No buffer: 0 | Pause: 0
Queue drops: 0 | LRO segments: 119m | LRO bytes: 16492m
Lacp PDU errors: 0
TRANSMIT
Total frames: 2522m | Frames/second: 15032 | Total bytes: 3644g
Bytes/second: 21724k | Total errors: 0 | Errors/minute: 0
Total discards: 0 | Queue overflow: 0 | Multi/broadcast: 54766
Collisions: 0 | Pause: 0 | Jumbo: 2376m
Cfg Up to Downs: 0 | TSO segments: 123m | TSO bytes: 3477g
Lagg no entries: 0
DEVICE
LINK INFO
Media state: active | Up to downs: 1
