DS224C の 2 台の電源装置ユニット( PSU )には、センサー読み取り値はありませんが、正常に機能しています
環境
- DS224c
- DS212
- ONTAP 9
問題
DS224cの両方のPSUにセンサー読み取り値がありません。エラーステータスがAutoSupportから次のログとして表示されます。
環境:
Channel: 1c
Shelf: 22
SES device path: local access: 1c.22.99
Module type: IOM12; monitoring is active
Shelf status: critical condition
SES Configuration, shelf 22:
logical identifier=XXXXXXXXXXXXXXX
vendor identification=NETAPP
product identification=DS224-12
product revision level=0230
Vendor-specific information:
Product Serial Number: XXXXXXXXXXXXXXX
Status reads attempted: 52454055; failed: 0
Control writes attempted: 0; failed: 0
Shelf bays with disk devices installed:
23, 22, 21, 20, 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0
with error: none
Power Supply installed element list: 1, 2; with error: none
Power Supply information by element:
[1] Serial number: XXXXXXXXXXXXXXX Part number: 114-00148+C0
Type: 7D
Firmware version: 0111 Swaps: 0
[2] Serial number: XXXXXXXXXXXXXXX Part number: 114-00148+C0
Type: 7D
Voltage Sensor installed element list: 1, 2, 3, 4; with error: none
Shelf voltages by element:
[1] <N/A> sensor condition <N/A>
[2] <N/A> sensor condition <N/A>
[3] <N/A> sensor condition <N/A>
[4] <N/A> sensor condition <N/A>
Current Sensor installed element list: 1, 2, 3, 4; with error: none
Shelf currents by element:
[1] 0 mA Normal current range
[2] 0 mA Normal current range
[3] 0 mA Normal current range
[4] 0 mA Normal current range
Cooling Unit installed element list: 1, 2, 3, 4; with error: 1, 2, 3, 4
Cooling Units by element:
[1] 0 RPM
[2] 0 RPM
[3] 0 RPM
[4] 0 RPM
Temperature Sensor installed element list: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11; with error: none
Shelf temperatures by element:
[1] 22 C (71 F) (ambient) Normal temperature range
[2] 23 C (73 F) Normal temperature range
[3] 23 C (73 F) Normal temperature range
[4] 23 C (73 F) Normal temperature range
[5] 23 C (73 F) Normal temperature range
[6] 23 C (73 F) Normal temperature range
[7] 23 C (73 F) Normal temperature range
[8] Unavailable
[9] Unavailable
[10] 29 C (84 F) Normal temperature range
[11] 29 C (84 F) Normal temperature range
Temperature thresholds by element:
[1] High critical: 52 C (125 F); high warning: 47 C (116 F)
Low critical: 0 C (32 F); low warning: 5 C (41 F)
[2] High critical: 60 C (140 F); high warning: 55 C (131 F)
[3] High critical: 60 C (140 F); high warning: 55 C (131 F)
[4] High critical: 60 C (140 F); high warning: 55 C (131 F)
[5] High critical: 60 C (140 F); high warning: 55 C (131 F)
[6] High critical: 62 C (143 F); high warning: 57 C (134 F)
[7] High critical: 100 C (212 F); high warning: 90 C (194 F)
[8] High critical: 62 C (143 F); high warning: 57 C (134 F)
[9] High critical: 100 C (212 F); high warning: 90 C (194 F)
[10] High critical: 90 C (194 F); high warning: 85 C (185 F)
[11] High critical: 90 C (194 F); high warning: 85 C (185 F)
ES Electronics installed element list: 1, 2; with error: none
ES Electronics reporting element: 1
ES Electronics information by element:
[1] Serial number: XXXXXXXXXXXXXXX Part number: 111-02850+C2
CPLD version: 24 Swaps: 0
[2] Serial number: XXXXXXXXXXXXXXX Part number: 111-02850+C2
Enclosure element list: 1; with error: none;
Enclosure information:
[1] WWN: XXXXXXXXXXXXXXX Shelf ID: 22
Serial number: XXXXXXXXXXXXXXX Part number: 116-00514+C0
Midplane serial number: XXXXXXXXXXXXXXX Midplane part number: 110-00541+A0
ストレージ障害:
Enclosure Status: critical
Channel: 1c
Shelf: 22
Shelf Type: DS224-12
Product Serial Number: XXXXX1111111111
Module Type: IOM12
Disk Elements:
Element Status Status Bytes Status Descriptions
0 [Bay 0]: NONCRITICAL 03,00,00,00
1 [Bay 1]: NONCRITICAL 03,01,00,00
2 [Bay 2]: NONCRITICAL 03,02,00,00
3 [Bay 3]: NONCRITICAL 03,03,00,00
4 [Bay 4]: NONCRITICAL 03,04,00,00
5 [Bay 5]: NONCRITICAL 03,05,00,00
6 [Bay 6]: NONCRITICAL 03,06,00,00
7 [Bay 7]: NONCRITICAL 03,07,00,00
8 [Bay 8]: NONCRITICAL 03,08,00,00
9 [Bay 9]: NONCRITICAL 03,09,00,00
10 [Bay 10]: NONCRITICAL 03,0A,00,00
11 [Bay 11]: NONCRITICAL 03,0B,00,00
12 [Bay 12]: NONCRITICAL 03,0C,00,00
13 [Bay 13]: NONCRITICAL 03,0D,00,00
14 [Bay 14]: NONCRITICAL 03,0E,00,00
15 [Bay 15]: NONCRITICAL 03,0F,00,00
16 [Bay 16]: NONCRITICAL 03,10,00,00
17 [Bay 17]: NONCRITICAL 03,11,00,00
18 [Bay 18]: NONCRITICAL 03,12,00,00
19 [Bay 19]: NONCRITICAL 03,13,00,00
20 [Bay 20]: NONCRITICAL 03,14,00,00
21 [Bay 21]: NONCRITICAL 03,15,00,00
22 [Bay 22]: NONCRITICAL 03,16,00,00
23 [Bay 23]: NONCRITICAL 03,17,00,00
Power Supplies:
1: OK 01,00,00,A0 RQSTED ON
2: UNKNOWN 06,00,00,A0 RQSTED ON
Fans:
1: CRITICAL 02,00,00,F0 OFF, FAIL
2: CRITICAL 02,00,00,F0 OFF, FAIL
3: CRITICAL 02,00,00,F0 OFF, FAIL
4: CRITICAL 02,00,00,F0 OFF, FAIL
Temperature Sensors:
1: OK 01,00,2A,00
2: OK 01,00,2B,00
3: OK 01,00,2B,00
4: OK 01,00,2B,00
5: OK 01,00,2B,00
6: OK 01,00,2B,00
7: OK 01,00,2B,00
8: UNKNOWN 06,00,2E,00
9: UNKNOWN 06,00,2E,00
10: OK 01,00,31,00
11: OK 01,00,31,00
Enclosure Electronics:
1 [IOM12 A] : OK 01,00,01,80 REPORT
2 [IOM12 B] : OK 01,00,00,80
OPS Panel:
1: OK 01,00,00,00
Enclosure:
1: OK 01,00,02,00 FAIL
Voltage Sensors:
1: UNKNOWN 06,00,00,00
2: UNKNOWN 06,00,00,00
3: UNKNOWN 06,00,00,00
4: UNKNOWN 06,00,00,00
Current Sensors:
Vendor Unique Element 83-IOM12: (SAS)
1 [IOM12 A] : CRITICAL 02,08,00,A4 MASTER, RESERVED, RESERVED, RESERVED
2 [IOM12 B] : CRITICAL 02,00,00,A4 RESERVED, RESERVED, RESERVED
Vendor Unique Element 85-IOM12: (ACP)
1 [IOM12 A] : OK 01,18,00,00 NO ACPP, INBACP
2 [IOM12 B] : OK 01,18,00,00 NO ACPP, INBACP
Input Power Monitor:
