メインコンテンツへスキップ
SyncMirror エラー:現在のディスクプール割り当てでは、 SyncMirror でミラーリングされたアグリゲートの障害分離は保証されません
1
Visibility:
Internal
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
に適用されます
  • ローカル同期ミラー
  • アドバンストディスクパーティショニング( ADP )
問題
ローカルの SyncMirror の作成に失敗しました。
aggr mirror -aggregate <aggregate> -mirror-partitionlist <partition_list> -simulate true
Error: command failed: Aggregate mirroring would fail for aggregate "<aggregate>" on node "<node>". Reason: Current disk pool assignments do not guarantee fault isolation for aggregates mirrored with SyncMirror. Other disks in the loop are in a different pool than disks: "disk_id", "disk_id". Use "disk show -v" to view and "disk assign" to change the disk pool assignments.
New to NetApp?
This is an internal KB article and its content should not be copy/pasted and shared with people outside of NetApp. Always seek Duty Manager authentication of caller for password reset requests. If you need further assistance post a question in Knowledge Xchange
