ONTAP は SMB2 または SMB3 ディレクトリの作成レイテンシを追跡しますか?
環境
ONTAP 9
回答
具体的にはなく、ディレクトリ作成のレイテンシが smb2オブジェクトのカウンタに集約されます create_latency
例:
Cluster::> set diag Warning: These diagnostic commands are for use by NetApp personnel only. Do you want to continue? {y|n}: y Cluster::*> statistics show-periodic -object smb2 -counter query_directory_latency -instance svm0 -node node1 Cluster: smb2.svm0: 3/10/2022 19:51:25 query directory Complete Number of latency Aggregation Constituents --------- ----------- ------------ 0us n/a n/a 0us n/a n/a 0us n/a n/a 0us n/a n/a Cluster: smb2.svm0: 3/10/2022 19:51:33 query directory Complete Number of latency Aggregation Constituents --------- ----------- ------------ Minimums: 0us - - Averages for 4 samples: 0us - - Maximums: 0us - - Cluster::*> statistics show-periodic -object smb2 -counter create_latency -instance svm0 -node node1 Cluster: smb2.svm0: 3/10/2022 19:54:04 create Complete Number of latency Aggregation Constituents -------- ----------- ------------ 0us n/a n/a 0us n/a n/a Cluster: smb2.svm0: 3/10/2022 19:54:08 create Complete Number of latency Aggregation Constituents -------- ----------- ------------ Minimums: 0us - - Averages for 2 samples: 0us - - Maximums: 0us - -
追加情報
smb2このオブジェクトには SMB3 処理が含まれます。
