メインコンテンツまでスキップ
Kubernetes ポッドの Trident ポッドが適切に終了していません
19
Visibility:
Votes:
0
Category:
trident-kubernetes
Specialty:
snapx
Last Updated:
に適用されます
Kubernetes/OpenShift 向け Trident
問題
Trident 関連ポッドのリストには、次のように表示されます。
NAME                               READY   STATUS        RESTARTS   AGE   IP              NODE              NOMINATED NODE   READINESS GATES
trident-csi-4cbtt                  2/2     Running       4          96d  <MASTER_IP_1>   caas-master01-01 <none>          <none>
trident-csi-5b59f59cc8-9wqp5       5/5     Running       0          11h  <NODE_IP_11>    caas-node01-01   <none>          <none>
trident-csi-5b59f59cc8-m9tdz       5/5     Terminating   0          12h  <NODE_IP_22>    caas-node02-02   <none>          <none>
trident-csi-dl972                  2/2     Running       6          96d  <NODE_IP_22>    caas-node03-03   <none>          <none>
trident-csi-h25g4                  2/2     Running       6          96d  <MASTER_IP_1>   caas-master03-03 <none>          <none>
trident-csi-nzzgj                  2/2     Running       4          96d  <MASTER_IP_1>   caas-master02-02 <none>          <none>
新しい Trident プロビジョニングポッドでは、次のエラーが発生します。
time="2020-11-30T23:55:58Z" level=error msg="Trident REST interface was not available after 30.00 seconds."
time="2020-11-30T23:55:58Z" level=debug msg="Updating Trident Provisioner CR after failed installation." name=trident namespace=tridenttime="2020-11-30T23:55:58Z" level=info msg="'TridentProvisioner' CR updated." name=trident namespace=trident
time="2020-11-30T23:55:58Z" level=error msg="error syncing 'trident/trident': reconcile failed; error re-installing Trident 'trident' in namespace 'trident'; err: reconcile failed;
       unable to upgrade connection: Authorization error (user=kube-apiserver-kubelet-client, verb=create, resource=nodes, subresource=proxy);
       use 'tridentctl logs' to learn more, requeuing"
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
