メインコンテンツへスキップ
Element Softwareの「Drive has failed SMART health check」アラート
48
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
環境
  • NetApp Element Software
  • NetApp SolidFire SFシリーズ
  • NetApp Hシリーズ
問題
NetApp SolidFire Active IQのエラー:
  • エラーコード:driveHealthFault
  • 詳細: Drive with serial: <xxxxxxxxxx> in slot: <y> has failed SMART overall health check
    • 例: Drive with serial: S3SZABCD01234 in slot: 3 has failed SMART overall health check
  • 詳細: Drive with serial: <xxxxxxxxxx> in slot: <y>, Drive should be replaced. SMART data indicates Non-volatile capacitance is failing, raw critical bytes 0-11: 0x10 0x2a 0x01 0x64 0x0a 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    • 例: Drive with serial: S3T2NX0M305154 in slot: 7, Drive should be replaced. SMART data indicates Non-volatile capacitance is failing, raw critical bytes 0-11: 0x10 0x2a 0x01 0x64 0x0a 0x00 0x00 0x00 0x00 0x00 0x00 0x00
  • エラー コード: driveHealthFault
  • 詳細: Drive with serial: <xxxxxxxxxx> in slot: <y>, Drive should be replaced. SMART data indicates health failed, raw critical bytes 0-11: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    • Drive with serial: S2TVNB0KA04565 in slot: 1, Drive should be replaced. SMART data indicates health failed, raw critical bytes 0-11: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
  • 詳細: Drive with serial: <xxxxxxxxxx> in slot: <y>, Drive should be replaced. SMART data indicates it is read only, raw critical bytes 0-11: 0x08 0x31 0x01 0x5e 0x0a 0x00 0x00 0x00 0x00 0x00 0x00 0x00"
    • : Drive with serial: S438NA0N609921 in slot: 0, Drive should be replaced. SMART data indicates it is read only, raw critical bytes 0-11: 0x08 0x31 0x01 0x5e 0x0a 0x00 0x00 0x00 0x00 0x00 0x00 0x00"
  • エラー コード: driveFailed
  • 詳細:1 drive(s) with state: "SmartHealthFailed" driveID: xx.
  • 詳細: 1 drive(s) with state: "NvmeReadOnly" driveID: xx.
New to NetApp?
  • この記事は役に立ちましたか?
