メインコンテンツまでスキップ
H410S の HCC アップグレードがシステムをアップグレードせずに完了します
環境
  • NetApp Element ソフトウェア
  • NetApp H410S の設置
  • BMC/IPMI
問題
  • アップグレードサイクルの最後まで実行され、一時停止ステータスに切り替えます
  • H410S システムがで新たに示されないとアップグレードされません HCC upgrade logs
    MainProcess-Upgrade-10.221.5.16 |         rtfi_node:35   | INFO   | Initiating Node Upgrade of node=<NAME> nodeID=1 with URL=file:///sf/downloads/solidfire-rtfi:12.3.2.3/filesystem.squashfs",
    MainProcess-uWSGIWorker3Core0   |       authorization:65   | INFO   | Getting certificate data from https://10.221.5.16/auth/.well-known/openid-configuration/jwks",
    MainProcess-Upgrade-10.221.5.16 |         rtfi_node:55   | INFO   | Current Node Upgrade Status: https://10.221.5.9:442/config/rtfi/status/current.json",
    MainProcess-Upgrade-10.221.5.16 |       base_monitor:73   | INFO   | RtfiMonitor started.",
    MainProcess-Upgrade-10.221.5.16 |       rtfi_monitor:183  | INFO   | Node upgrade status: PrepareURTFI 0%: Prepare uRTFI inplace processing",
    MainProcess-Upgrade-10.221.5.16 |       rtfi_monitor:183  | INFO   | Node upgrade status: URTFIStopServices 0%: Stopping all systemd services and sockets",
    MainProcess-Upgrade-10.221.5.16 |       rtfi_monitor:183  | INFO   | Node upgrade status: FinishFailure 0%: RTFI Rollback complete",
    MainProcess-Upgrade-10.221.5.16 |       rtfi_monitor:82   | WARNING | RTFI Monitor: NODE 1 RTFI HIT FAILED STATE.",
  • NetApp SolidFire Active IQ イベント:
    304828
    2022-03-01 12:14:47
    upgradeEvent
    Storage node upgrade: Failed software update
    -   2   -
    { "packageName": "12.3.2.3", "nodeName": "<NAME>" }
New to NetApp?
