ANDUの一時停止: Firmware updateが原因でノードが「waiting for giveback」状態ではない
環境
- ONTAP 9
- 自動無停止アップグレード(ANDU)
問題
パートナーが「waiting for giveback」状態でないため、自動無停止アップグレード(ANDU)が一時停止しています。これは、次の2つの方法のいずれかで示されています。
1.EMSイベント upgrademgr.update.pausederr:ERROR またはAutoSupport EMSアラート callhome.andu.pausederr:alert
例:
[node-01: upgrademgr: upgrademgr.update.pausederr:ERROR]: The automated update of the cluster has been paused due to the following reason: Node "node-01": Error: {Node "node-02" is not in "waiting for giveback" state.}, Action: {Use the "storage failover show" to verify that node "node-02" is in one of the following states: "waiting for giveback" or "connected".}.
または
[node-01: notifyd: callhome.andu.pausederr:alert]: params: {'epoch': '91e735df-158b-4999-8546-5523299458af', 'subject': 'AUTOMATED NDU PAUSED'}
2. cluster image show-update-progressに示されているように
例:
::> cluster image show-update-progress
Estimated Elapsed
Update Phase Status Duration Duration
Pre-update checks completed 00:10:00 00:00:35
Data ONTAP updates paused-on-error 01:23:00 00:37:18
Details:
Node name Status Status Description
node-01 waiting
node-02 failed Error: Node "node-02" is not in
Action: Use the "storage failover
node-03 waiting
node-04 waiting
9 entries were displayed.
Status: Paused - An error occurred in "Data ONTAP updates" phase. The update cannot continue until the error has been
resolved. Resolve all issues, then use the "cluster image resume-update" command to resume the update.
