メインコンテンツへスキップ
EMSにsecd.kerberos.clockskewが表示されると認証に失敗し、CIFS/SMBにアクセスできません
39
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
環境
ONTAP 9
問題
  • EMSでsecd.kerberos.clockskewが表示されると、認証に失敗するためCIFS/SMBにアクセスできない
  • また、受信済み - secd.cifsAuth.problem: vserver (txhous10fps06vf_ldc) General CIFS authentication problem. Error: User authentication procedure failed
  • 一部のCIFS/SMBクライアントで遅延の兆候が見られるが、他のクライアントでは見られない
  • IPを介した共有へのアクセスは成功するが、ホスト名(\\hostname)またはFQDN(\\hostname.domain.com)を介したアクセスは失敗する
  • SECD.log
 ERR  :  RESULT_ERROR_SECD_NO_SERVER_AVAILABLE:6940 in secd_rpc_auth_extended_1_svc() at authentication/secd_rpc_auth.cpp:749
 debug:  SecD RPC Server sending reply to RPC 151: secd_rpc_auth_extended  { in secdSendRpcResponse() at server/secd_rpc_server.cpp:1405 }
 ERR  :  Error: User authentication procedure failed
 ERR  :   [  0 ms] Login attempt by domain user 'CIFSLABAdministrator' using NTLMv1 style security
 ERR  :   [    0] No servers available for MS_NETLOGON, vserver: 3, domain: cifs.lab.netapp.com.
 ERR  :   [   22] Unable to connect to any of the provided DNS servers
 ERR  :   [   22] Connecting to NetLogon server a7-6.cifs.lab.netapp.com (172.17.192.24)
 ERR  :  **[   22] FAILURE: Unexpected state: Error 6810 at file:Common/ProtocolClientLibrary/Dns/DnsOps.cpp func:DnsNameLookup line:715
''' ERR  :  **[   33] FAILURE: Cluster and Domain Controller times differ by more than the configured clock skew'''
 ERR  :   [   104] Unable to connect to a7-6.cifs.lab.netapp.com through the 10.53.21.46 interface
 ERR  :   [   104] No servers available for MS_NETLOGON, vserver: 3, domain: cifs.lab.netapp.com.
|          RPC completed at Fri Oct 19 08:34:13 2012           |
|         End of log for failed RPC secd_rpc_auth_extended         |
  • EMS メッセージ
10/18/2012 13:34:59 krbClus-01     ERROR     secd.kerberos.clockskew: Kerberos client or node clock skew error (-1765328351).
  • パケットトレースは KRB5KRB_AP_ERR_TKT_NYV
A packet trace is only needed from the client to confirm this - we'd see a KRB5 packet:
1778   41.215954     172.17.193.122  10.53.21.46    SMB    Session Setup AndX Request
1779   41.227968     10.53.21.46    172.17.193.122  SMB    KRB Error: KRB5KRB_AP_ERR_TKT_NYV, Error: STATUS_MORE_PROCESSING_REQUIRED
New to NetApp?
