ボリュームクォータサイズが変更されたあとにボリュームでクォータを作成できません
に適用されます
ONTAP 9
問題
- ボリュームクォータサイズが変更されたあとにボリュームでクォータを作成できません。
例:
Cluster::> quota on -vserver svm -volume volname
Cluster::> quota status -vserver svm -volume volname
Vserver Name: svm
Volume Name: volname
Quota State: Quotas are initializing and transferring rules
Vserver Name: svm
Quota State: Quotas are off
- EMS ログで、ユーザ名が見つからないために UNIX ユーザ検索が失敗したあとにクォータ処理の失敗を確認できます。
例:
[nodename mgwd: mgmtgwd.jobmgr.jobcomplete.failure:info]: Job "Quota Operation" [id 10254] ("quota on" performed for quota policy "default" on volume "volname" in Vserver "svm") completed unsuccessfully: User name user1 not found. Reason: SecD Error: libc returned a transient error. Please look at the journal for detail. (1258185)......[nodename : secd: secd.unixLookupFailure:error]: vserver (svm) UNIX lookup failure. Error: Acquire UNIX credentials procedure failed
[ 1 ms] Successfully connected to ip 10.163.50.15, port 756 using TCP
[ 1] Unable to connect to NIS service on 10.163.50.15 (Error: Could not connect to server)
[ 1] No servers available for NIS, vserver: 11, domain: .
**[ 1] FAILURE: Unable to make a connection (NIS:), result: 6940
[ 1] Source: NIS unavailable. Ignoring and trying next available source for user-name: user1
[ 2] Entry for user-name: chenj not found in the current source: FILES. Entry for user-name: user1 not found in any of the available sources
[ 2] Unable to retrieve UID for UNIX user user1- MGWD ログを使用すると、詳細な失敗の進行状況を確認できます。
例:
[kern_mgwd:info:1684] 0x83725b600: 8603e900000133b0: ERR: VOPL::QuotaOps: JOB[10257]: pushRules: Cancel quota op after failure(User name user1 not found. Reason: SecD Error: libc returned a transient error. Please look at the journal for detail. ) from copy rules to zapi; retry count is 8
