メインコンテンツへスキップ
Active Directory へのログインに失敗したあとに遅延が発生することはありません アカウント
131
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
に適用されます
ONTAP 9
問題
ドメインユーザに対して、「 Delay after each Failed Login attempt 」パラメータが機能していません。変更内容が適用されるのはローカルユーザのみです。
例:
cluster_1::*> security login role config show -role admin -instance
                                          Vserver: vserver_1
                                        Role Name: admin
                 Minimum Username Length Required: 3
                           Username Alpha-Numeric: disabled
                 Minimum Password Length Required: 8
                           Password Alpha-Numeric: enabled
Minimum Number of Special Characters Required in the Password: 0
                       Password Expires In (Days): unlimited
   Require Initial Password Update on First Login: disabled
                Maximum Number of Failed Attempts: 0
                    Maximum Lockout Period (Days): 0
                      Disallow Last 'N' Passwords: 6
            Delay Between Password Changes (Days): 0
     Delay after Each Failed Login Attempt (Secs): 4
Minimum Number of Lowercase Alphabetic Characters Required in the Password: 0
Minimum Number of Uppercase Alphabetic Characters Required in the Password: 0
Minimum Number of Digits Required in the Password: 0
Display Warning Message Days Prior to Password Expiry (Days): unlimited
                        Account Expires in (Days): unlimited
Maximum Duration of Inactivity before Account Expiration (Days): unlimited
New to NetApp?
