メインコンテンツまでスキップ
CNA カードの Transmit-Total Errors カウンタに誤った「 ifstat 」値が表示される
111
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
network
Last Updated:
のしんだ
に適用されます
  • ONTAP 9.2P4
  • QLogic 統合ネットワークアダプタ( CNA ) 8324
問題
  • イベントログには、次のエラーが記録されます
例:
4/18/2019 11:35:16  FAS2620_0125    ALERT      vifmgr.cluscheck.crcerrors: Port e0c on node FAS2620_0125 is reporting a high number of observed hardware errors, possibly CRC errors.
 4/18/2019 10:31:05  FAS2620_0126    ALERT      vifmgr.cluscheck.crcerrors: Port e0c on node FAS2620_0126 is reporting a high number of observed hardware errors, possibly CRC errors.
 4/18/2019 10:30:16  FAS2620_0125    ALERT      vifmgr.cluscheck.crcerrors: Port e0c on node FAS2620_0125 is reporting a high number of observed hardware errors, possibly CRC errors.
 4/18/2019 09:26:05  FAS2620_0126    ALERT      vifmgr.cluscheck.crcerrors: Port e0c on node FAS2620_0126 is reporting a high number of observed hardware errors, possibly CRC errors.
  • "ifstat -a"に、 Transmit-Total Errors カウンタを示します
例:
-- interface  e0c  (260 days, 7 hours, 2 minutes, 13 seconds) --
RECEIVE
 Total frames:   28041m | Frames/second:   1247  | Total bytes:    31031g
 Bytes/second:    1379k | Total errors:     0  | Errors/minute:     0
 Total discards:    0  | Discards/minute:    0  | Multi/broadcast:   254m
 Non-primary u/c: 27985m | CRC errors:      0 | Runt frames:      0
 Fragment:       0  | Long frames:      0  | Jabber:        0
 Alignment errors:   0  | No buffer:       0  | Xon:          0
 Xoff:         0  | Jumbo:         0  | Noproto:        0
 Error symbol:     0  | Illegal symbol:    0  | Bus overruns:     0
 LRO segments:   18989m | LRO bytes:     30180g | LRO6 segments:     0
 LRO6 bytes:      0  | Bad UDP cksum:     0  | Bad UDP6 cksum:    0
 Bad TCP cksum:     0  | Bad TCP6 cksum:    0  | Mcast v6 solicit:   0
TRANSMIT
 Total frames:   16313m | Frames/second:    725  | Total bytes:      0
 Bytes/second:     0  | Total errors:   38007m | Errors/minute:    101k
 Multi/broadcast:   788k | Max collisions:    0  | Single collision:   0
 Multi collisions:   0  | Late collisions:    0  | Xon:          0
 Xoff:         0  | Jumbo:         0  | Cfg Up to Downs:    0
 TSO non-TCP drop:   0  | Split hdr drop:    0  | Timeout:        0
 TSO segments:    5957m | TSO bytes:     39976g | TSO6 segments:     0
 TSO6 bytes:      0  | HW UDP cksums:     0  | HW UDP6 cksums:    0
 HW TCP cksums:     0  | HW TCP6 cksums:    0  | Mcast v6 solicit:   0
New to NetApp?
