予期しない停電が発生した場合は、ルートボリュームのリカバリが必要になります
- 65
- Visibility:
- Public
- Votes:
- 1
- Category:
- ontap-9
- Specialty:
- core<a>1017031</a><a>1005546</a><a>Root Volume Recovery</a><a>(</a><a>ルートボリュームリカバリ</a><a>)の停電 </a>
- Last Updated:
のしんだ
環境
- ONTAP 9
- 停電によるシャットダウン
問題
予期しない停電が発生すると、 ONTAP は次のメッセージで起動します。
The contents of the root volume may have changed and the local management configuration may be inconsistent and/or the local management databases may be out of sync with the replicated databases. This node is not fully operational.
Contact support personnel for the root volume recovery procedures.
[cluster:callhome.root.vol.recovery.reqd:EMERGENCY]: Call home for ROOT VOLUME NOT WORKING PROPERLY: RECOVERY REQUIRED.
Internal error: Cannot open corrupt replicated database. Automatic recovery attempt has failed or is disabled. Check the event logs for details. This node is not fully operational. Contact support personnel for the root volume recovery procedures.
