メインコンテンツまでスキップ
オンボードキー管理( OKM )を使用している場合:キークエリの実行時に、一部のノードに VEK が表示されません
72
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
環境
  • ONTAP 9.6
  • オンボードキーマネージャ( OTM )
問題
VEK は、実行時に一部のノードの下に表示されません "security key-manager key query"
Cluster::*> key-manager key query
  (security key-manager key query)
   Vserver: Cluster
 Key Manager: onboard
     Node: Cluster-01
  Key Server: ""
Key Tag                 Key Type  Restored
Cluster-01               NSE-AK   true
   Key ID: 000000000000000002000000000001003260fcee69xxxx88155e8f9511a75680000000000000000
   Key ID: 00000000000000000200000000000100354a30c9xxxx1b4ea18d772a94dc398d0000000000000000
Cluster-01               SVM-KEK   true
   Key ID: 00000000000000000200000000000a002c38fab416e3d9xxx8c0876576160ff0000000000000000
   Key ID: 00000000000000000200000000000a008a2aafe553axxxxc2f1d1429014c35c70000000000000000
   Vserver: Cluster
     Node: Cluster-02
  Key Server: ""
Cluster-02                NSE-AK   true
   Key ID: 000000000000000002000000000001003260fcee69xxxxd88155e8f9511a75680000000000000000
SVM1                  VEK     true
   Key ID: 00000000000000000200000000000500950bdf38a251b7xxxxac5acae751d5aa0000000000000000
SVM1                  VEK     true
   Key ID: 00000000000000000200000000000500a3896a2b6ab5xxxx6387c9b52c31005c0000000000000000
Cluster-02               SVM-KEK   true
   Key ID: 00000000000000000200000000000a002c38fab416e3d9xxxx8c0876576160ff0000000000000000
10 entries were displayed.
If any listed keys have "false" in the "Restored" column, run the "security key-manager external restore" command to restore the keys that are stored on an external key server and run the "security key-manager onboard sync" command to synchronize the keys that are part of the onboard key hierarchy.
ノードに次のキーが表示されないことを確認します。 Cluster-01 :
SVM1                  VEK     true
SVM1                  VEK     true
New to NetApp?
