ディスクシェルフの電源に障害が発生しました
に適用されます
DS4246
問題
Power supply failed can be found in the following command output.
例:
storage show fault
Customer Problem Summary :
Enclosure Status: critical
Channel: 0c
Shelf: 34
Shelf Type: DS4246
Product Serial Number: SHJSG1542000146
Module Type: IOM6
Power Supplies:
Element Status Status Bytes Status Descriptions
1: CRITICAL 02,00,00,F0 OFF, RQSTED ON, FAIL
2: OK 01,00,00,20 RQSTED ON
3: NOT INSTALLED 05,00,00,20
4: OK 01,00,00,20 RQSTED ON
