「 System Health Alert Show 」は、ノードのサービスプロセッサにネットワーク接続がないことを示しています
のしんだ
に適用されます
- ONTAP 9
- サービス プロセッサ(SP)
問題
SP の「」にネットワーク接続がないというエラーが発生system health alert show
しました。
例:
cluster1::> system health alert show
Node: node1
Resource: SP Config
Severity: Major
Indication Time: Tue Aug 27 23:50:13 2019
Suppress: false
Acknowledge: false
Probable Cause: Service Processor in node node1 has no network
connectivity.The cable between the Wrench port on the
controller and the ethernet switch is disconnected.
Possible Effect: You might not be able to use the Service Processor to
remotely access, monitor, and troubleshoot your
storage system.
Corrective Actions: 1. Check the connection between the Wrench port and the ethernet switch.
2. If the cable is properly connected, ensure that the Service Processor's ethernet interface is configured properly by executing the command "system service-processor network show".
3. Check for network cable related issues.
4. Contact the technical support if the alert persists.
