メインコンテンツまでスキップ
「Waiting for cluster applications to come online on the local node」というメッセージは、テイクオーバー後に表示され、ギブバックできません
195
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
環境
  • FAS2650
  • ONTAP 9
  • サービス プロセッサ(SP)
問題
  • システムでテイクオーバーが発生すると、というメッセージWaiting for cluster applications to come online on the local node.が表示され、ギブバックできません。
例:
::> storage failover show
        Takeover
Node       Partner     Possible State Description
fas2650-a         fas2650-b   true    Connected to fas2650-b
fas2650-b         fas2650-a   true    Connected to fas2650-a.  Waiting for cluster applications to come online on the local node.
2 entries were displayed.
cluster1::> set diag
cluster1::*> cluster kernel-service show
Master       Cluster       Quorum Availability  Operational
Node        Node        Status     Status     Status
fas2650-a   fas2650-a   in-quorum    true operational
             fas2650-b   out-of-quorum false     unknown
fas2650-b   fas2650-a out-of-quorum false      operational
             fas2650-b   out-of-quorum true      operational
4 entries were displayed.
cluster1::*> cluster kernel-service node show
         Is    Cluster
Node        Master Node        Status     Status Status
fas2650-a  true   fas2650-a in-quorum    true      operational
fas2650-b  true   fas2650-a  out-of-quorum false     operational
cluster1::> storage failover giveback -ofnode fas2650-b -override-vetoes true
Warning: Initiating a giveback with vetoes overridden will result in giveback
     proceeding even if the node detects outstanding issues that would make
     a giveback dangerous or disruptive. Do you want to continue?
      {y|n}: y
Error: command failed: Failed to initiate giveback. Reason: A giveback is
    already in progress.
  • EMSログは、bsdsocketエラーとSPLinkDownAlertメッセージのあとに表示されます。
例:
  [?] Fri Jul 10 18:34:40 JST [fas2650-a: kernel: bsdsocket.queueLimit.reached:error]: Number of connection requests for the socket bound to port 935 having the IP address * has reached the limit of 1536 connections. The socket uses TCP protocol. This event has occurred 62 times since the last warning.
  [?] Fri Jul 10 18:35:16 JST [fas2650-a: dsa_vmm: hamsg.noSend:debug]: params: {'req_op': '6', 'remoteID': 'bb7f5031722311e7ab45a7880059a5e9', 'status': '1', 'scope_err': '0', 'scope': '16'}
  [?] Fri Jul 10 18:40:00 JST [fas2650-a: kernel: bsdsocket.queueLimit.reached:error]: Number of connection requests for the socket bound to port 935 having the IP address * has reached the limit of 1536 co
nnections. The socket uses TCP protocol. This event has occurred 49 times since the last warning.
  [?] Fri Jul 10 18:40:41 JST [fas2650-a: dsa_vmm: hamsg.noSend:debug]: params: {'req_op': '6', 'remoteID': 'bb7f5031722311e7ab45a7880059a5e9', 'status': '1', 'scope_err': '0', 'scope': '16'}
  [?] Fri Jul 10 18:45:13 JST [fas2650-a: spmd: spm.servprocd.process.exit:alert]: Service processor daemon (servprocd) with ID 4174 exited as a result of normal exit (1). This server will attempt to restart.
  [?] Fri Jul 10 18:45:15 JST [fas2650-a: servprocd: mdb.recovery.successful:debug]: params: {'name': 'servprocd'}
  [?] Fri Jul 10 18:46:06 JST [fas2650-a: dsa_vmm: hamsg.noSend:debug]: params: {'req_op': '6', 'remoteID': 'bb7f5031722311e7ab45a7880059a5e9', 'status': '1', 'scope_err': '0', 'scope': '16'}
  [?] Fri Jul 10 18:50:19 JST [fas2650-a: nphmd: hm.alert.cleared:info]: params: {'alert_id': 'SPLinkDownAlert', 'alerting_resource': 'SP Config', 'detailed_info': 'Alert Id = SPLinkDownAlert , Alerting Resource = SP Config', 'monitor': 'controller'}
New to NetApp?
