メインコンテンツへスキップ
SAS シェルフ ACP プロセッサ「 X 」の ACP プロセッサエラー
80
Visibility:
Votes:
0
Category:
fas-systems<a>2008722973</a>
Specialty:
hw
Last Updated:
環境
ONTAP 9
問題
症状 1 :
次のシェルフ障害エラーが表示されます。
Sat Mar 19 22:41:51 EST [xxx:ses.status.ACPError:CRITICAL]: DS4246 (S/N XXXXXXXXX) shelf 11 on channel 2c ACP Processor error for SAS shelf ACP processor 2: critical status ; Alternate Control Path hardware failed This module is on the rear of the shelf at the bottom center, on shelf module B.
Sat Mar 19 22:41:54 EST [xxx:monitor.shelf.fault:CRITICAL]: Fault reported on disk storage shelf attached to channel 1b. Check fans, power supplies, disks, and temperature sensors. Sat Mar 19 22:41:54 EST [xxx:callhome.shlf.fault:error]: Call home for SHELF_FAULT
症状 2
STORAGE-ACP ログには次のステータスが表示されます。
ACP Connectivity Status: Partial Connectivity
A)      Shelf Module Reset Cnt IP Address FW Version Module Type Status
2c.11.B 000  192.168.1.185  02.08   IOM6   inactive (rebooting
B)     Shelf Module Reset Cnt IP Address FW Version Module Type Status
2c.11.B  000  192.168.1.185  02.08   IOM6  not-responding (last contact at: "Sat Mar 19 22:32:42 EST 2016")
現象 3 :
filer>storage show fault
Enclosure Status: critical
Channel: 1b
Shelf: 11
Shelf Type: DS4246
Product Serial Number: XXXXXXXXX
Module Type: IOM6
Vendor Unique Element 85-IOM6: (ACP)
Element Status Status Bytes Status Descriptions
1 [IOM6 A] : OK 01,70,00,80
2 [IOM6 B] : CRITICAL 02,00,00,40 FAIL
症状 4
filer>environment status shelf
Module type: IOM6; monitoring is active
Shelf status: critical condition
SES Configuration, shelf 11:
ACP installed element list: 1, 2; with error: 2
New to NetApp?
