メインコンテンツへスキップ
AFF A400 / FAS8300 / FAS8700 shutts down with nvmem.battery.noChargeアラート
858
Visibility:
Votes:
1
Category:
aff-series
Specialty:
hw
Last Updated:
環境
  • AFF A400
  • AFF C400
  • ASA A400
  • ASA C400
  • FAS8300
  • FAS8700
問題
  • 予期しないノードシャットダウン
コンソールログ
  • ブート時のコンソールメッセージ:
 WARNING:  The battery is experiencing a critical failure:
    - Battery is not present
   Without a working battery, the system cannot retain data
   during a power outage, which can result in data loss.
   Power down the system and verify that the battery is
   properly installed.
   To ignore this failure and boot the system in a mode
   where data loss might occur, press 'c' followed by 'Enter'
EMSログ
  • ノードのシャットダウン前に次のいずれかのエラーが報告されます。
    • NVMEMバッテリの充電を要求しています
[node_name: env_mgr: nvmem.battery.noCharge:alert]: The NVMEM battery is requesting to be charged but the charger is not charging the battery. To prevent data loss, the system will shut down in 20 minutes.
[node_name: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (no charge) CRITICAL.
[node_name: env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery not charging)
or
<callhome_battery_failure_1
     subject="BATTERY (current high)"/>
<monitor_shutdown_emergency_1
     reason="Environmental Reason Shutdown (Battery current critical)"
  • NVMEM バッテリがありません
Thu Feb 03 13:57:59 +0000 [node-01: env_mgr: nvmem.battery.notPresent:alert]: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.
  • NVRAMバッテリ残量が危険なほど低下しています
Thu Feb 03 14:00:00 +0000 [node-01: statd: monitor.nvramLowBattery:EMERGENCY]: NVRAM battery is dangerously low.
  • 次のAutoSupport件名メッセージ が報告されます。
HA Group Notification from node_name (BATTERY (no charge)) EMERGENCY or
HA Group Notification (BATTERY (no charge)) EMERGENCY
  • パートナーがテイクオーバーを実行:
[node_name: cf_main: cf.fsm.firmwareStatus:info]: Failover monitor: partner Halted
[node_name: cf_main: cf.fsm.takeover.on.halt:info]: Failover monitor: Node initiated automatic takeover after detecting that its partner node has halted.
問題を確認するには、次のいずれかの方法を使用します。
BMCプロンプト
  1. 次のコマンドを実行します。
BMC node_name>system battery show
  1. 結果で次のことを確認します。
    1. Current フィールドに 0 mAと表示されます。
    2. RelativeCharge 71% の下にフィールドが表示されます。
    3. ChargingCurrent フィールドに1000 mAと表示されます。
AutoSupportログ
  1. BATTERY (no charge)というタイトルのAutoSupport を開きます
  2. SP-LATEST-STATISTICS セクションに移動します。
  3. 出力 で次のことを確認します。
    1. Log Collection Time 現在の日付を表示します(現在の日付/時刻が表示されない場合は、AutoSupportセクションSP - latest-statisticsを使用して確認しないでください)
    2. Current フィールドに 0 mAと表示されます。
    3. RelativeCharge 71% の下にフィールドが表示されます。
    4. ChargingCurrent フィールドに1000 mAと表示されます。
  4. PLATFORM-SENSORS.XML セクションに移動します。
  5. 出力 で、次のshowコマンドのうち1つ以上を failed  または fault として確認します。
    1. DBlade Battery Voltage
    2. Battery Charge Failed?
    3. Battery Charge
    4. Bat Charging State
New to NetApp?
  • この記事は役に立ちましたか?
