イメージの自動ブートに失敗したため、 ANDU が一時停止しました。ファイルシステムが認識されない( -29 )
環境
- FAS2552
- FAS2554
- ONTAP 9
問題
cluster_CLI::> cluster image show-update-progress
Estimated Elapsed
Update Phase Status Duration Duration
Pre-update checks completed 00:10:00 00:00:35
Data ONTAP updates paused-on-error 01:23:00 00:37:18
Details:
Node name Status Status Description
node-01 waiting
node-02 failed Error: Node "node-02" is not in
"waiting for giveback" state.
Action: Use the "storage failover
show" to verify that node
"node-02" is in one of the
following states: "waiting for
giveback" or "connected".
4 entries were displayed.
Status: Paused - An error occurred in "Data ONTAP updates" phase. The update cannot continue until the error has been
resolved. Resolve all issues, then use the "cluster image resume-update" command to resume the update
影響を受けるノードの SP ログに、新しいデフォルトイメージをブートできなかったことが記録されます。
Boot Loader version 4.3 Copyright (C) 2000-2003 Broadcom Corporation. Portions Copyright (C) 2002-2014 NetApp, Inc. All Rights Reserved. CPU Type: Intel(R) Xeon(R) CPU C3528 @ 1.73GHz Starting AUTOBOOT press Ctrl-C to abort... File system not recognized (errcode=-29) Trying to boot from alternative path:fat://boot0/X86_64/kernel/primary.krn Autoboot the image failed. File system not recognized (-29)
LOADER> SP 経由でログインすると、プロンプトにノードが表示されます。
