マザーボード交換後、PCMが「incorrect NVMEM battery is installed」というメッセージとともに起動に失敗する
環境
- AFF A400、AFF C400、ASA A400、ASA C400、FAS8700、FAS8300
- AFF C190、AFF A150、AFF A220、ASA A150、FAS2750、FAS2720
- AFF A800、AFF C800、ASA A800、ASA C800
問題
- 環境セクションのモデルのマザーボード(PCM)交換後、ブート中に次のエラーが発生します:
Apr 27 08:31:18 [Node1:nvmem.battery.unread:EMERGENCY]: The NVMEM battery state cannot be determined because the 'Bat Initial FCC' sensor is unreadable. To prevent data loss, the system will shut down in 5 minutes.
Apr 27 08:31:18 Power outage protection flash de-staging: 28 cycles
WARNING: The battery is unfit to retain data during a power
outage. This is likely because the battery is
discharged but could be due to other temporary
conditions.
When the battery is ready, the boot process will
complete and services will be engaged.
To override this delay, press 'c' followed by 'Enter'
Apr 27 08:32:18 [Node1:callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Initial FCC' unreadable) CRITICAL.
Apr 27 08:32:19 [Node1:nvmem.battery.packInvalid:EMERGENCY]: The incorrect NVMEM battery is installed. Expected part number is 271-00045. To prevent data loss, the system will shut down in 5 minutes.
Apr 27 08:32:49 [Node1:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (invalid pack) CRITICAL.
* Power Fail - Please Wait *
または
WARNING: The battery is experiencing a critical failure:
- Invalid battery pack is detected
Without a working battery, the system cannot retain data
during a power outage, which can result in data loss.
Power down the system and verify that the battery is
properly installed.
To ignore this failure and boot the system in a mode
where data loss might occur, press 'c' followed by 'Enter'
- その後、ノードはシャットダウンを実行します。
