メインコンテンツへスキップ
両方の HA コントローラについて、すべての SAS ポートがオフラインの状態でリブートが繰り返します すぐに起動します
環境
  • ONTAP 9
    • disk.checksum.offlineAdapter
問題
次のエラーが表示されたコントローラのブート障害:
[localhost:disk.checksum.offlineAdapter:error]: Adapter 0a taken offline due to checksum verification failure on multiple disks.
[localhost:disk.checksum.offlineAdapter:error]: Adapter 0b taken offline due to checksum verification failure on multiple disks.
[localhost:config.noPartnerDisks:CRITICAL]: No disks were detected for the partner; this node will be unable to takeover correctly
すべてのSASアダプタがオフラインの場合は、次のエラーが表示されます。
WARNING: 0 disks found!
Storage Adapters found:
0 Fibre Channel Storage Adapters found!
2 SAS Adapters found!
Jun 29 17:20:39 [cluster1-01:cf.fm.noMBDisksOrIc:error]: Could not find the local mailbox disks. Could not determine the firmware state of the partner through the HA interconnect.
0 Parallel SCSI Storage Adapters found!
0 ATA Adapters found!
Select option 4 from the boot menu to choose disks for the root volume and spare core space.
Target Adapters found:
4 Fibre Channel Target Adapters found!
0 iSCSI Target Adapters found!
WARNING: there do not appear to be any disks attached to the system.
No root volume found.
Rebooting... (press ctrl-c during boot to break reboot loop)
New to NetApp?
