メインコンテンツまでスキップ
テイクオーバー後に「 Call home for disk redundancy failed 」アラートが表示される
58
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
環境
  • 8.2.5P5 7-Mode
  • FAS2552
問題
  • EMS log ショー Call home for DISK REDUNDANCY FAILED:
[?] Sun Jul 25 09:59:00 CST [Node_B: dsa_disc: shelf.config.tospha:info]: System has transitioned to single path HA attached storage
[?] Sun Jul 25 09:59:00 CST [Node_B: dsa_disc: callhome.dsk.redun.fault:error]: Call home for DISK REDUNDANCY FAILED
  • ポート 0b がオフラインになりました:
slot 0: SAS Host Adapter 0b (PMC-Sierra PM8001 rev. C, SAS, <OFFLINE (hard)>)
        Firmware rev:     01.12.09.00
        Base WWN:      x:xxxxx:xxxxxxx:xx
        Phy State:      [4] Enabled, Rate unknown
                  [5] Enabled, Rate unknown
                  [6] Enabled, Rate unknown
                  [7] Enabled, Rate unknown
  • EMS ログには e がありますrror information about port 0b :
[?] Sun Jul 25 09:43:16 CST [Node_B: pmcsas_intrd_0: sas.port.down:warning]: SAS port "0b" went down.
[?] Sun Jul 25 09:43:47 CST [Node_B: sinai_link_mgr: cf.ic.sbb:debug]: HA interconnect: SBB Compatibility Event. No compatible partner node found. The interconnect device has been disabled.
[?] Sun Jul 25 09:44:02 CST [Node_B: pmcsas_timeout_0: sas.adapter.debug:info]: params: {'debug_string': 'Link down too long ... offlining', 'adapterName': '0b'}
[?] Sun Jul 25 09:44:02 CST [Node_B: pmcsas_timeout_0: sas.link.error:error]: Could not recover link on SAS adapter 0b after 45 seconds. Offlining the adapter.
[?] Sun Jul 25 09:44:02 CST [Node_B: pmcsas_asyncd_0: sas.adapter.debug:info]: params: {'debug_string': 'pmcsas_asyncd_offline', 'adapterName': '0b'}
New to NetApp?
Scan to view the article on your device
