メインコンテンツまでスキップ
Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
StorageGRID で ONTAP 証明書の有効期限が切れたあとにクラウド階層を使用できなくなりました
環境
  • FabricPool
  • ONTAP
  • StorageGRID
問題
  1. ONTAP で StorageGRID 証明書の有効期限が切れたあとでオブジェクトストアを使用できなくなります
  2. 証明書の検証を有効にすると次のエラーが発生して失敗します
Cannot verify availability of the object store from node NodeAa. Reason: Cannot verify the certificate given by the object store server.
It is possible that the certificate has not been installed on the cluster.
Use the 'security certificate install -type server-ca' command to install it..
EMS.log:
[NodeAa: ktlsd: ktls.failed:notice]: "The TLS connections have failed several times with remote host '10.3.3.123' in IPspace '1234', for which the latest reason given is: OpenSSL: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed."
[nodeAa: OscHighPriThreadPool: object.store.unavailable:EMERGENCY]: Unable to connect to the object store "<Fabric Pool>" from node <node ID>. Reason: Connection unavailable.
SKtrace.log:
2021-08-19T16:09:07Z 12420711494086901 [12:0] OSC_ERR: logFailedCmd:356 HEAD Cmd ID:128 failed with OSC error: -336134278
2021-08-19T16:09:07Z 12420711494089813 [12:0] OSC_ERR: logFailedCmd:367 Stats of HEAD Cmd ID:128, wait 125483us, start-send 126651us, 1stbyte 0us, 1st-lastbyte 0us
2021-08-19T16:09:08Z 12420713417698175 [4:0] OSC_ERR: logFailedCmd:351 PUT Cmd ID:128 name:config_test_b01af070-8ea1-11e8-9eb6-529269fb1459 failed with OSC error: -336134278
2021-08-19T16:09:08Z 12420713417701232 [4:0] OSC_ERR: logFailedCmd:367 Stats of PUT Cmd ID:128, wait 127049us, start-send 127167us, 1stbyte 0us, 1st-lastbyte 0us
2021-08-19T16:09:09Z 12420715329109906 [15:0] OSC_ERR: logFailedCmd:351 PUT Cmd ID:128 name:config_test_b01af070-8ea1-11e8-9eb6-529269fb1459 failed with OSC error: -336134278
2021-08-19T16:09:09Z 12420715329112830 [15:0] OSC_ERR: logFailedCmd:367 Stats of PUT Cmd ID:128, wait 124031us, start-send 124137us, 1stbyte 0us, 1st-lastbyte 0us
2021-08-19T16:09:10Z 12420717245482467 [13:0] OSC_ERR: logFailedCmd:351 PUT Cmd ID:128 name:config_test_b01af070-8ea1-11e8-9eb6-529269fb1459 failed with OSC error: -336134278
2021-08-19T16:09:10Z 12420717245485368 [13:0] OSC_ERR: logFailedCmd:367 Stats of PUT Cmd ID:128, wait 123929us, start-send 124031us, 1stbyte 0us, 1st-lastbyte 0us
2021-08-19T16:09:12Z 12420719162024136 [13:0] OSC_ERR: logFailedCmd:351 PUT Cmd ID:128 name:config_test_b01af070-8ea1-11e8-9eb6-529269fb1459 failed with OSC error: -336134278
2021-08-19T16:09:12Z 12420719162027261 [13:0] OSC_ERR: logFailedCmd:367 Stats of PUT Cmd ID:128, wait 123943us, start-send 124047us, 1stbyte 0us, 1st-lastbyte 0us
New to NetApp?
Scan to view the article on your device
