メインコンテンツまでスキップ
Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
停電後にコントローラをブートできない
5
Visibility:
Votes:
0
Category:
fas-systems<a>2009310376</a>
Specialty:
hw
Last Updated:
環境
  • FAS2750
  • DS224C
問題
  • 電源停止後、コントローラをブートできず、シェルフIDは88と表示されます
  • BMCログからPSUステータスが正常ではない
Sensor Name        State      Current   Critical    Warning    Warning   Critical
Reading     Low      Low      High     High
Bat FRU LED                 OFF
Battery RemCap Desc            READY
Battery Charge Failed?           FALSE
Battery Charge Bad?            FALSE
Battery Capacity Message          GOOD
Voltage Spike Frequency  normal        0      --      --      --       3
Voltage Status               GOOD
Temp Low Shutdown               UP
Temp High Shutdown              UP
SNMP Bad Fan Count            MULTI_FAILED
Chassis is Under Temp             NO
Chassis is Over Temp             NO
PSU2 Bad          invalid       --
PSU1 Bad          invalid       --
PSU2            invalid       --
PSU1            invalid       --
PSU2 ON          invalid       --
PSU1 ON          invalid       --
PSU1 INFO                 FRU_AVAIL
PSU1 INFO                 FRU_AVAIL
PSU1 FRU                 MULTIFAULT
PSU2 FRU                 MULTIFAULT
Partner Status              A_SIDE_PRESENT
PSU1 Present               PRESENT
PSU1 5V          not_available    -- mV     --      --      --      --
PSU1 12V          not_available    -- mV     --      --      --      --
PSU1 5V Curr        not_available    -- mA     --      --      --      --
PSU1 12V Curr       not_available    -- mA     --      --      --      --
PSU1 Fan 1         not_available    -- RPM    --      --      --      --
PSU1 Fan 2         not_available    -- RPM    --      --      --      --
PSU1 Inlet Temp      init_failed     -- C     -20 C     --      --      -20 C
PSU1 Hotspot Temp     init_failed     -- C     -20 C     --      --      -20 C
PSU2 Present               PRESENT
  • 保守モードで sysconfig -v はシェルフ0のすべてのディスクが表示されません
         Mini-SAS HD Vendor:     Molex Inc.
         Mini-SAS HD Part Number:   112-00435+A0
         Mini-SAS HD Type:      Passive Copper (unequalized) 0.5m ID:00
         Mini-SAS HD Serial Number: 906130996
         ID    Vendor   Model       FW   Size
         01.0 : NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.1 : NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.2 : NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.3 : NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.4 : NETAPP   X341_SSKBE900A10 NA02 857.0GB (1758174768 520B/sect)
         01.5 : NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.6 : NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.7 : NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.8 : NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.9 : NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.10: NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.11: NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.12: NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.13: NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.14: NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.15: NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.16: NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.17: NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.18: NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.19: NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.20: NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.21: NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.22: NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         01.23: NETAPP   X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
         Shelf 0: DS224-12  Firmware rev. IOM12E A: 0120  IOM12E B: 0120
         Shelf 1: DS224-12  Firmware rev. IOM12 A: 0230  IOM12 B: 0230
New to NetApp?
Scan to view the article on your device
