メインコンテンツへスキップ
SPNotConfiguredAlertを抑制する方法
83
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
core
Last Updated:
環境
  • FAS2720
  • FAS2750
  • サービスプロセッサSP
説明
SPNotConfiguredAlert は、お客様がSPネットワークを設定する意思がない場合に生成されます。
Cluster::> system health alert show -instance
            Node: Cluster-1
          Monitor: controller
          Alert ID: SPNotConfiguredAlert
     Alerting Resource: SP Config
         Subsystem: Service-Processor
      Indication Time: Wed Sep 28 19:39:56 2022
     Perceived Severity: Major
       Probable Cause: Configuration_error
        Description: Service Processor is not properly configured.
     Corrective Actions: 1. Use the "system service-processor network modify" command to configure the network interface of the Service Processor.
               2. Use the "system service-processor image modify -node Cluster-1 -autoupdate true" to configure AutoUpdate feature of the Service Processor.
               3. Contact the technical support if the alert persists.
      Possible Effect: You might not be able to use the Service Processor to remotely access, monitor, and troubleshoot your storage system.
        Acknowledge: false
          Suppress: false
           Policy: SPNotConfiguredAlertPolicy
        Acknowledger: -
         Suppressor: -
   Additional Information: Status: online
               Configured: false
               Firmware Version: 5.10
               Booted Version :  primary
               Public Link Status:  down
               Warning Count: 5
               Link Warning Count: 5
   Alerting Resource Name: SP Config
   Additional Alert Tags: device
