メインコンテンツへスキップ
クラスタポートで多数のCRCエラーが発生する
228
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
環境
  • ONTAP 9
  • スイッチレス クラスタ
問題
  • 次のクラスタポートでCRCエラーが複数回カウントされます: ifconfig:
-- interface  e0b  (232 days, 2 hours, 21 minutes, 3 seconds) --
RECEIVE
 Total frames:    252m | Frames/second:    13  | Total bytes:    39644m
 Bytes/second:    1977  | Total errors:    1218  | Errors/minute:     0
 Total discards:    0  | Discards/minute:    0  | Multi/broadcast:  1020k
 Non-primary u/c:    0  | CRC errors:     1212  | Runt frames:      0
 Fragment:       0  | Long frames:      0  | Jabber:        3
 Length errors:     3  | No buffer:       0  | Xon:          0
 Xoff:         0  | Pause:         0  | Jumbo:       1293k
 Noproto:        0  | Error symbol:    236  | Illegal symbol:   199
 Bus overruns:     0  | Queue drops:      0  | LRO segments:    249m
 LRO bytes:     26713m
| LRO6 segments:     0  | LRO6 bytes:      0
 Bad UDP cksum:     0  | Bad UDP6 cksum:    0  | Bad TCP cksum:     0
 Bad TCP6 cksum:    0  | Mcast v6 solicit:   0
TRANSMIT
 Total frames:    561m | Frames/second:    28  | Total bytes: 139g
 Bytes/second:    6980  | Total errors:     0  | Errors/minute:     0
 Total discards:    0  | Queue overflow:    0  | Multi/broadcast:  1031k
 Xon:          0  | Xoff:         0  | Pause:         0
 Jumbo:       2565k | Cfg Up to Downs:    2  | TSO non-TCP drop:   0
 Split hdr drop:    0  | Timeout:        0  | TSO segments:    402k
 TSO bytes:     4840m | TSO6 segments:     0  | TSO6 bytes:      0
 HW UDP cksums:    154k | HW UDP6 cksums:    0  | HW TCP cksums:    556m
 HW TCP6 cksums:    0  | Mcast v6 solicit:   0
DEVICE
 Mcast addresses:    3  | Rx MBuf Sz:     4096
LINK INFO
 Speed:       10000M | Duplex:       full | Flowcontrol:     none
 Media state:    activ
e | Up to downs: 8
  • EMSエラーメッセージで次の出力が1時間ごとに継続的に表示されます。
Tue Dec 01 04:04:26 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
Tue Dec 01 05:04:27 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
Tue Dec 01 06:04:27 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
Tue Dec 01 07:04:27 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
Tue Dec 01 08:04:28 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
Tue Dec 01 09:04:29 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
  • 上記のエラーメッセージは、HAパートナーコントローラe0bポート間のケーブルを切り離して交換しても停止しません。
::> event log show
Time         Node Severity    Event
1/5/2021 15:11:21 node 2   ERROR      netif.linkErrors: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicat
1/5/2021 14:54:52   node 1   EMERGENCY    vifmgr.clus.linkdown: The cluster port e0b on node node 1 has gone down unexpectedly.
1/5/2021 14:54:52   node 2   EMERGENCY    vifmgr.clus.linkdown: The cluster port e0b on node node 2 has gone down unexpectedly.
1/5/2021 14:11:20   node 2   ERROR      netif.linkErrors: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
1/5/2021 13:11:20   node 2   ERROR netif.linkErrors: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
1/5/2021 12:11:19   node 2   ERROR      netif.linkErrors: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port,
Press <space> to page down, <return> for next line, or 'q' to quit... q
6 entries were displayed.
  • これはスイッチレスクラスタ構成です。ターゲットe0bポートは、クラスタLIFポートとしてノード1 e0bとノード2 e0bを直接接続するポートです。
  • ケーブル交換後もCRCエラー数が増え続け、エラーが引き続き報告される
  • 速度とデュプレックスに接続された各ノードでポートに違いはなく、SFPなどのトランシーバは使用されません。
  • CrossConnecting showエラーはポートに残り、ケーブルに追従しません。
New to NetApp?
