メインコンテンツまでスキップ
NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
システムIDの競合が原因でMetroCluster の設定が失敗する
Visibility:
Votes:
0
Category:
metrocluster
Specialty:
metrocluster<a>2008666813</a><a>(翻訳用</a>
Last Updated:
環境
  • MetroCluster の設定
  • FASシステム
  • ONTAP 9
問題
MetroCluster の設定が失敗し、次の情報が表示さ
CLUSTER::> metrocluster configure [Job 259] Configuring Clusters[Job 259] Job failed: Configure command failed on node "NODE-1" in the local cluster. Reason: (Local node's system id in the nodelist does not match the NVRAM system id). Check the hardware for errors and make sure all remote nodes are online, then try the command again with "-refresh true". Use the "metrocluster operation show" command to view detailed error information. Resolve the errors, then try the command again.
New to NetApp?
Scan to view the article on your device
