メインコンテンツへスキップ
EMS の「 shelf_fault 」が「 SES.status.ACPError : Critical 」と報告されます。
135
Visibility:
Votes:
0
Category:
fas-systems<a>1008459</a><a>ACP</a><a>2008515250</a>
Specialty:
hw
Last Updated:
のしんだ
環境
  • I/O モジュール( IOM )
  • Alternate Control Path(ACP)
  • サービス プロセッサ(SP)
問題
例:
Sat Mar 19 22:41:51 EST [xxx:ses.status.ACPError:CRITICAL]: DS4246 (S/N XXXXXXXXX) shelf 11 on channel 2c ACP Processor error for SAS shelf ACP processor 2: critical status ; Alternate Control Path hardware failed This module is on the rear of the shelf at the bottom center, on shelf module B.
Sat Mar 19 22:41:54 EST [xxx:monitor.shelf.fault:CRITICAL]: Fault reported on disk storage shelf attached to channel 1b. Check fans, power supplies, disks, and temperature sensors.
Sat Mar 19 22:41:54 EST [xxx:callhome.shlf.fault:error]: Call home for SHELF_FAULT
ACP出力:
Cluster::> storage shelf acp module show -node node1
Node         Module Name     State
node1        x.x.B        active
          x.x.A        rebooting
Cluster::> node run -node node1 acpadmin ibacp_list_all
Number of ACP modules 2
MAC         SES   Last Contact  Protocol   Assigner   Shelf        Current Inband   IOM    shelf
Address       bit   (seconds ago) Version   ACPA ID    S/N         State   ID     Type   flag
00:a0:98:d5:29:c3  01    599374    1.2.02.12  0       xxxxx1809000006   0xd   0a.00.B IOM6   0x20
00:a0:98:d5:2e:73  01    123     1.2.02.12   0       xxxxx1809000006  0x17  0a.00.A IOM6   0x20
New to NetApp?
