メインコンテンツまでスキップ
Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
SP 情報が正しく表示されない
119
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
に適用されます
FAS2650
問題
  • SP のヘルスがデグレードと表示される。
Node03::> system health subsystem show
Subsystem Health
SAS-connect ok
Environment ok
Memory ok
Service-Processor degraded
Node03::> system health alert show
Node: Node03-02
Resource: SP Config
Severity: Major
Indication Time: Tue Jan 19 09:21:38 2021
Suppress: false
Acknowledge: false
Probable Cause: Service Processor in node Node03-02 has no network
         connectivity.The cable between the Wrench port on the
         controller and the ethernet switch is disconnected.
Possible Effect: You might not be able to use the Service Processor to
         remotely access, monitor, and troubleshoot your
         storage system.
Corrective Actions: 1. Check the connection between the Wrench port and the ethernet switch.
           2. If the cable is properly connected, ensure that the Service Processor's ethernet interface is configured properly by executing the command "system service-processor network show".
           3. Check for network cable related issues.
           4. Contact the technical support if the alert persists.
  • ノード node03-02 の情報を表示できません。
Node03::> system service-processor show
IP Firmware
Node Type Status Configured Version IP Address
Node03-01 SP online true 5.1P1 XXX.XXX.XXX.XXX
Error: show failed: RPC: Unable to send
Node03::> system service-processor network show
Address
Node Status Family Link State IP Address
Node03-01 online IPv4 up XXX.XXX.XXX.XXX
DHCP: none
MAC Address: XX:XX:XX:XX:XX:XX
Network Gateway: XXX.XXX.XXX.XXX
Network Mask (IPv4 only): XXX.XXX.XXX.XXX
Prefix Length (IPv6 only): -
IPv6 RA Enabled: -
Subnet Name: -
SP Network Setup Status: succeeded
2 entries were displayed.
  • ただし、 sysconfig -a で、警告 LED が消灯し、 SP のステータスがオンラインになっています
Node03::> node run -node * sysconfig -a
Node: Node03-02
NetApp Release 9.1P11: Thu Dec 21 02:32:26 PST 2017
Service Processor Status: Online
Firmware Version: 5.1P1
Mgmt MAC Address: XX:XX:XX:XX:XX:XX
Ethernet Link: up, full duplex, auto-neg complete
Using DHCP: no
IPv4 configuration:
IP Address: XXX.XXX.XXX.XXX
Netmask: XXX.XXX.XXX.XXX
IPv6 configuration: Disabled
  • SP を再起動しても問題を解決できない。
New to NetApp?
Scan to view the article on your device
