メインコンテンツまでスキップ
Nblade.vldbタイムアウトによるサービス停止
15
Visibility:
Votes:
0
Category:
fas-systems<a>MGWD</a><a>サービス停止</a><a>–</a><a>翻訳</a><a>用2008639790 </a>
Specialty:
core
Last Updated:
環境
  • ONTAP 9
問題
予期 nodewatchdog.svc.rpc.noresp, Nblade.vldb.Timeout, ucore.panicString しないLIFフェイルオーバーが発生し、その後、システムがメッセージを示します。データサービスを利用できません。
例:
clustermgt::*> network interface show -is-home !true
Logical    Status     Network            Current       Current Is
Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
cluster
cluster-1  up/up    xxx.xxx.xxx.xxx/24     clustermgt-03  a0a     false
cluster-2  up/up    xxx.xxx.xxx.xxx/24     clustermgt-03  a0a     false
cluster-3  up/up    xxx.xxx.xxx.xxx/24     clustermgt-03  a0a     false
cluster-4  up/up    xxx.xxx.xxx.xxx/24     clustermgt-03  a0a     false
clustermgt
clustermgt-00  up/up    xxx.xxx.xxx.xxx/24     clustermgt-02  e0M     false
clustermgt_01 ALERT  nodewatchdog.svc.rpc.noresp: The mgwd service internal to Data ONTAP that is required for continuing data service was unavailable. The service failed, but was unsuccessfully restarted.
clustermgt_01 ERROR  Nblade.vldb.Timeout: Request from the network module to the volume location database (VLDB) timed out.
clustermgt_01 ERROR  ucore.panicString: 'mgwd: Received SIGABRT (Signal 6) at RIP 0x8195c030c (pid 2409, uid 0, timestamp 1612452192).'
clustermgt_01 ERROR   ucore.error: Could not dump core for process ID 2409 (mgwd). Reason: coredump "/mroot/etc/crash/mgwd.2409.0537090897.1612452192.ucore" failed: error 4.
clustermgt_01 ALERT   nodewatchdog.svc.rpc.noresp: The mgwd service internal to Data ONTAP that is required for continuing data service was unavailable. The service failed, but was restarted.
New to NetApp?
