メインコンテンツまでスキップ
Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
クラスタ IP は、で約 1 分間切断されます e0M ポートの接続が解除されました
53
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
に適用されます
FAS2750
問題
次のログでは、アンプラグは 13 : 16 : 27 であることがわかりますが、ポートリンクは 13 : 17 : 33 で識別されています。
ping コマンドの出力:
"OK","2020/10/09 13:16:26","172.27.17.11","172.27.17.11","Time: 0ms",""
"NG","2020/10/09 13:16:27","172.27.17.11","","Request timed out",""
"NG","2020/10/09 13:17:36","172.27.17.11","","Request timed out",""
"OK","2020/10/09 13:17:37","172.27.17.11","172.27.17.11","Time: 0ms",""
EMS
[?] Fri Oct 09 13:17:33 +0900 [p-dc2-fas-01-01: mgmt_port_link_status_poll: netif.linkDown:info]: Ethernet Wrench Port: Link down, check cable.
[?] Fri Oct 09 13:17:36 +0900 [p-dc2-fas-01-01: vifmgr: vifmgr.portdown:notice]: A link down event was received on node p-dc2-fas-01-01, port e0M.
[?] Fri Oct 09 13:17:36 +0900 [p-dc2-fas-01-01: vifmgr: vifmgr.lifdown.noports:alert]: LIF p-dc2-fas-01-01_mgmt1 (on virtual server 4294967295), IP address 172.27.17.12, currently cannot be hosted on node p-dc2-fas-01-01, port e0M, or any of its failover targets, and is being marked as down.
[?] Fri Oct 09 13:17:36 +0900 [p-dc2-fas-01-01: vifmgr: vifmgr.lifBeingRemoved:notice]: LIF p-dc2-fas-01-01_mgmt1 (on virtual server 4294967295), IP address 172.27.17.12, is being removed from node p-dc2-fas-01-01, port e0M.
[?] Fri Oct 09 13:17:36 +0900 [p-dc2-fas-01-01: vifmgr: vifmgr.lifmoved.linkdown:notice]: LIF cluster_mgmt (on virtual server 4294967295), IP address 172.27.17.11, is being moved to node p-dc2-fas-01-02, port e0M.
[?] Fri Oct 09 13:17:36 +0900 [p-dc2-fas-01-01: vifmgr: vifmgr.lifBeingRemoved:notice]: LIF cluster_mgmt (on virtual server 4294967295), IP address 172.27.17.11, is being removed from node p-dc2-fas-01-01, port e0M.
New to NetApp?
Scan to view the article on your device
  • この記事は役に立ちましたか?
