メインコンテンツまでスキップ
Why does node report ADP disabled while upgrading ONTAP or reboot
160
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS
  • AFF
  • ONTAP 8.3.1 and later
Answer
  • Advanced Disk Partitioning (ADP) is enabled by default on all FAS/AFF models running ONTAP 8.3.1 or higher.
  • However, ONTAP disables the ADP feature when it is not needed. Possible scenarios include:
    • Systems using unpartitioned disks for root aggregates.
    • Systems using technologies such as Storage Pool, MCC-FC etc.
  • On such systems, when the node gets reinitialized during the ONTAP upgrade, ADP is disabled again so that its original system configuration remains the same.
Additional Information
N/A
