メインコンテンツへスキップ
Brocadeスイッチに電源装置の障害が表示されている
424
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
環境
Brocadeスイッチ
問題
  • スイッチPSUに黄色のライトが表示される、またはリンクライトが表示されない
  • chassisshowで確認
  • sensorshowはPSU2を「faulty」、Fan 2を「Unknown」と報告します。
sensorshow     :
sensor  1: (Temperature) is Ok, value is 39 C
sensor  2: (Fan 1 ) is Ok,speed is 6617 RPM
sensor  3: (Fan 2 ) is Unknown
sensor  4: (Power Supply) is Ok
sensor  5: (Power Supply) is Faulty
  • psshow は電源装置 2 を 障害として報告します:
psshow     :
Power Supply #1 is OK
Power Supply #2 is faulty
  • fanshow はファン2を 不明として報告:
fanshow     :
Fan 1 is Ok, speed is 6617 RPM
Fan 2 is Unknown
  • errdumpによると、PS1、PS2、Fan2の両方が故障していることが確認できました:
2023/06/21-14:13:39, [EM-1034], 88278, CHASSIS, ERROR, Brocade, PS 2 set to faulty, rc=2000e.
2023/06/21-14:13:41, [FW-1010], 88279, FID 128, WARNING, Brocade, Env Power Supply 2, is below low boundary(High=0, Low=1). Current value is 0 (1 OK/0 FAULTY).
2023/06/21-14:13:41, [FW-1424], 88280, FID 128, WARNING, Brocade, Switch status changed from HEALTHY to MARGINAL.
2023/06/21-14:13:41, [FW-1427], 88281, FID 128, WARNING, Brocade, Switch status change contributing factor Power supply: 1 bad.
2023/06/21-14:13:56, [EM-1034], 88293, CHASSIS, ERROR, Brocade, PS 1 set to faulty, rc=2000e.
2023/06/21-14:14:00, [FW-1010], 88294, FID 128, WARNING, Brocade, Env Power Supply 1, is below low boundary(High=0, Low=1). Current value is 0 (1 OK/0 FAULTY).
2023/06/21-14:14:00, [FW-1424], 88295, FID 128, WARNING, Brocade, Switch status changed from HEALTHY to MARGINAL.
2023/06/21-14:14:00, [FW-1427], 88296, FID 128, WARNING, Brocade, Switch status change contributing factor Power supply: 1 bad.
2023/06/21-14:14:00, [EM-1037], 88298, CHASSIS, INFO, Brocade, PS 1 is no longer faulted.
2023/06/21-14:23:40, [HIL-1610], 88315, CHASSIS, WARNING, Brocade, Fan/PS unit 2 not supplying power, fan speeds may not be available. Please ensure that the unit has power and the switch is on.
2023/06/21-14:23:44, [FW-1431], 88316, FID 2, WARNING, Brocade, Switch status change contributing factor Fan: 1 bad.
2023/06/21-14:23:46, [FW-1431], 88317, FID 128, WARNING, Brocade, Switch status change contributing factor Fan: 1 bad
  • スイッチのPSUを交換する前に、電源コンセントやケーブルなど、サイト上で発生する可能性のある電源の問題をさらに除外するために、以下の手順を実行しました:
  1. 電源ケーブルが正しく接続されているか確認してください。
  2. 正常な電源ケーブルとスワップしてみてください。
  3. スイッチの電源コードとPSUを取り付け直してください。
  4. 外部電源装置が正常に動作していることを確認してください。
原因
電源装置の障害
New to NetApp?
