メインコンテンツまでスキップ
Brocade G610 が予期せずリブートされまし
2
Visibility:
Votes:
1
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
環境
  • BrocadeG610
  • FabOS 8.2.2
問題
  • Brocade G610 が明らかな理由なしに予期せず複数回リブートされました
errdump -a
2022/02/08-19:04:19, [HAM-1004], 238, CHASSIS, INFO, BrocadeG610, Processor rebooted - Reset.
2022/02/28-09:36:49, [HAM-1004], 246, CHASSIS, INFO, BrocadeG610, Processor rebooted - Reset.
2022/03/23-09:55:31, [HAM-1004], 261, CHASSIS, INFO, BrocadeG610, Processor rebooted - Reset.
psshow
Power Supply #1 is OK
fanshow
Fan 1 is Ok, speed is 7425 RPM
Fan 2 is Ok, speed is 7345 RPM
Fan 3 is Ok, speed is 7425 RPM
Fan 4 is Ok, speed is 7425 RPM
sensorshow
sensor 1: (Temperature) is Ok, value is 23 C
sensor 2: (Temperature) is Ok, value is 23 C
sensor 3: (Temperature) is Ok, value is 26 C
sensor 4: (Temperature) is Ok, value is 25 C
sensor 5: (Temperature) is Ok, value is 21 C
sensor 6: (Temperature) is Ok, value is 19 C
sensor 7: (Temperature) is Ok, value is 25 C
sensor 8: (Temperature) is Ok, value is 22 C
sensor 9: (Temperature) is Ok, value is 37 C
sensor 10: (Fan ) is Ok,speed is 7425 RPM
sensor 11: (Fan ) is Ok,speed is 7345 RPM
sensor 12: (Fan ) is Ok,speed is 7425 RPM
sensor 13: (Fan ) is Ok,speed is 7425 RPM
sensor 14: (Power Supply) is Ok
  • 電源ケーブルが正しく接続されていることを確認し、スイッチに電源を供給しているコンポーネント(ソケット、ライン、ケーブル、 UPS など)の正常性を確認しました。
  • 電源ケーブルとソケットをスワップしても問題 は維持されます
  • 同じ無停電電源装置( UPS ) / 回路上の他のコンポーネントは影響を受けません。
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
