メインコンテンツへスキップ
ONTAP のアップグレード後に、サポート対象の CN1610 スイッチについてサポート対象外の switch_alert が報告されました
100
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
HW
Last Updated:
環境
  • ONTAP のアップグレード
  • ONTAP 9.8
  • CN1610
  • FastPath バージョン( 1.3.0.3 )
問題
  • ONTAP 9.7Px から 9.8Px へのアップグレード
  • EMS アラートがすぐにトリガーされてクリアされます。
cshmd: hm.alert.raised:alert]: Alert Id = UnsupportedSwitch_Alert , Alerting Resource = Clusterswitch1 raised by monitor ethernet-switch
cshmd: hm.alert.cleared:notice]: Alert Id = UnsupportedSwitch_Alert , Alerting Resource = Clusterswitch1 cleared by monitor ethernet-switch
cshmd: hm.alert.raised:alert]: Alert Id = UnsupportedSwitch_Alert , Alerting Resource = Clusterswitch2 raised by monitor ethernet-switch
cshmd: hm.alert.cleared:notice]: Alert Id = UnsupportedSwitch_Alert , Alerting Resource = Clusterswitch2 cleared by monitor ethernet-switch
  • クラスタヘルスモニタ対処方法レポート:
::>system health alert definition show -node <nodename> -monitor cluster-switch -alert-id UnsupportedSwitch_Alert
            Node: <node name>
          Monitor: cluster-switch
       Class of Alert: UnsupportedSwitch_Alert
     Severity of Alert: Major
       Probable Cause: Configuration_error
Probable Cause Description: Unsupported cluster switch is detected.
      Possible Effect: Communication problems and cluster connectivity issues occur.
     Corrective Actions: Unsupported cluster switch "$(cluster_switch_support.device)" found. Connect a supported cluster switch to cluster network.
       Subsystem Name: Switch-Health
New to NetApp?
