メインコンテンツまでスキップ
Broadcom の SANnav アプライアンスを導入できません
17
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
環境
  • SANnav
  • ESXi 6.5
問題
ESX vCenter 6.5 で SANnavby ovftool を導入すると、ディスクが最大 100% インポートされますが、エラーが発生して失敗します
Error Connect to host :80
2020-09-08T15:00:32.743+02:00 verbose OVFTool[14024] [Originator@6876 sub=Default] file://:80/ is redirected to file://:80/
2020-09-08T15:00:32.743+02:00 verbose OVFTool[14024] [Originator@6876 sub=Default] Changing HttpWriterFactory path to file://:80
2020-09-08T15:00:32.743+02:00 verbose OVFTool[13800] [Originator@6876 sub=Default] Curl_perform error code 3 (URL using bad/illegal format or missing URL)
2020-09-08T15:00:32.743+02:00 verbose OVFTool[14024] [Originator@6876 sub=Default] Erasing open readers for Portal_2.1.0_bld248-distribution-file1.nvram
2020-09-08T15:00:32.743+02:00 verbose OVFTool[14024] [Originator@6876 sub=Default] CURL error buffer:
2020-09-08T15:00:32.790+02:00 verbose OVFTool[06204] [Originator@6876 sub=Default] Exception thrown: class boost::exception_detail::clone_impl>(Connection error: Failed to connect to host :80 due to URL using bad/illegal format or missing URL, please see the logs for more details)
--> [context]zKq7AVMEAQAAAOvm7wATT1ZGVG9vbAAAgz8hdm1hY29yZS5kbGwAANBIBgDG8wUARlsCAVRjAW92ZnRvb2wuZXhlAAHEgQ0BD2YNAbOcCwGhdwUBc2QFAepMBQGoeAUBJ3sFABe1GQBbyxkAAlMeAqD0AXVjcnRiYXNlLkRMTAADEhQAS0VSTkVMMzIuRExMAAT0VAFudGRsbC5kbGwA[/context]
2020-09-08T15:00:32.883+02:00 verbose OVFTool[06204] [Originator@6876 sub=Default] Backtrace:
New to NetApp?
Scan to view the article on your device
