メインコンテンツへスキップ
ノードレポートsplog.sp.not.accessible、ファイアウォールブロッキングポート50000(SP APIサービス用)
52
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
問題
  • 1 つのノードが、クラスター内の他のノードのSP/ BMCに servprocd 接続の問題を報告しています。例:
[node_name_03: servprocd: splog.sp.not.accessible:error]: The SP on the remote node (node_name_01) is not accessible because of The Service Processor on node "node_name_01" is not reachable. Verify that the SP or BMC is online, verify that api-service is enabled on the SP or BMC, verify that the partner node is running, check if pings from SP or BMC to partner node work, check if hw-assist keep-alives are normal, check that network ports are configured correctly and are functional (up). Then, try the command again..
[node_name_03: servprocd: splog.sp.not.accessible:error]: The SP on the remote node (node_name_02) is not accessible because of The Service Processor on node "node_name_02" is not reachable. Verify that the SP or BMC is online, verify that api-service is enabled on the SP or BMC, verify that the partner node is running, check if pings from SP or BMC to partner node work, check if hw-assist keep-alives are normal, check that network ports are configured correctly and are functional (up). Then, try the command again..
  • これらのメッセージは、 ONTAPまたはSP/ BMCファームウェアの更新後、
  • servprocdデーモンとapi-serviceがノード
  • HW-Assistで再起動され、ノードのmagnamente LIFとBMC IP間のpingテストが正常になった
    New to NetApp?
