InsightデータソースでBrocade portShowに失敗しました
環境
- OnCommand Insight(Insight)7.3.13
- Brocade データソース
問題
InsightデータソースでportShowコマンドがエラーで失敗しました:
20XX-01-02 00:31:41,290 WARN [com.onaro.sanscreen.acquisition.datasource.brocade.builders.BrocadeAbstractBuilder] [foundation] stars_ant_fab_A - XX.X.XXX.XXX - Unable to parse portshow: Invalid hex FCID length: 4 (expected 6)20XX-01-02 00:31:41,290 INFO [com.onaro.sanscreen.acquisition.datasource.brocade.builders.BrocadeAbstractBuilder] [foundation] stars_ant_fab_A - XX.X.XXX.XXX - Attempting to execute portshow on single ports from port index: 020XX-01-02 00:31:43,228 FATAL [com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource] [foundation] stars_ant_fab_A - Runtime exception: Command failed: portshowjava.lang.RuntimeException: Command failed: portshow...Caused by: java.lang.IllegalArgumentException: Invalid hex FCID length: 4 (expected 6)at com.onaro.sanscreen.acquisition.common.Fcid.toValue(Fcid.java:91) ~[brocade_cli.jar:?]at com.onaro.sanscreen.acquisition.common.Fcid.<init>(Fcid.java:60) ~[brocade_cli.jar:?]at com.onaro.sanscreen.acquisition.datasource.brocade.builders.BrocadePortBuilder.populateFromPortShowCommand(BrocadePortBuilder.java:537) ~[brocade_cli.jar:?]at com.onaro.sanscreen.acquisition.datasource.brocade.builders.BrocadePortBuilder.executeSinglePortShowCommand(BrocadePortBuilder.java:722) ~[brocade
